Old 08-04-2011, 12:38 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,849
The weight of paint
A gallon of paint can be pretty heavy, as a cat owner I am always concerned about weight.
Burnt paint scraped off and swept up off the floor seems to weigh much less that it did in the can. I assume that most of the chemicals that make it liquid evaporate off.
Has anyone made measurements of this.
Old 08-04-2011, 06:56 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1416 Posts: 2,251
An unfair comparison Frosty.
The burnt paint has lost most of the resin as well as the thinner that gave it the proper viscosity for a brush or roller. Burnt paint is mainly pigment and some inorganic filler.
Paint advertised as "high solid" has approx 60% solids, so still 40% liquids. Normal paint left in an opened can in the sun will loose more than 50% of its volume. Remaining weight will be more than 50% because some fillers like zinc are very heavy.
But I doubt your boat can sink from too much paint...
Old 08-04-2011, 07:34 AM
Rep: 1493 Posts: 7,447
The VOC content information is in the can. You can easily calculate what percentage of the weight will evaporate when the paint dries.
Old 08-04-2011, 08:57 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Now if you were transporting gallons and gallons of paint, this would be a different matter.
-Tom
Old 08-04-2011, 02:23 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Perhaps Frosty, you should indicate just how much paint you intend to put on the boat !
How many gallons have you in mind ?
Regards
Fanie
Water ! Just gimme water !
Old 08-04-2011, 03:33 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,355
Don't paint your cat. It will hate you and run away.
http://chainsgalore.com/2009/02-08/more-painted-cats/
Hoyt
Old 08-04-2011, 03:41 PM
Fanie's Avatar
Fanie
as a cat owner...
Cats don't have 'owners', they have servants
Regards
Fanie
Old 08-08-2011, 01:21 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
One of the US team in the 'Little Americas Cup' some years ago had a dull grey paint job.
After the undercoat was put on and polished, the skipper couldn't see the sense in applying another 25 kilos of bright topcoat.
I think they won that year.
Old 08-08-2011, 01:43 AM
Frosty's Avatar
Yes ive seen racing boats with bare epoxy on the inside you can see the sea passing the hull. The weight of paint is an important consideration in such circumstances in a boat where crews underpants are weighed along with anything else in your personal belongings.
Old 08-08-2011, 04:53 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Gonzo has it right, simple to work it out....the solvents go to heaven and the rest is the weight on the boat, or if you are Boston, the solvents go into polluting our already getting hotter planet......
Old 08-08-2011, 05:08 AM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 652
is that your cat hoyt, i know a few new zealanders that do a similar thing to their sheep.
brendan .
Old 08-08-2011, 05:13 AM
hoytedow's Avatar
Resistor
It's going to be a cold winter.
Hoyt
Old 08-08-2011, 08:48 AM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
I always appreciate an honorable mention ;-)
I am skeptical of the deniers diatribe
Old 08-08-2011, 10:12 AM
Frosty's Avatar
Ok lets look at this Gonzo says look at the VOC--now I dont know what that is so dont laugh if I guess it as Volume of can so what does that mean.
Old 08-08-2011, 11:05 AM
Rep: 1758 Posts: 1,561
VOC = volatile organic compounds, i.e. the solvent that evaporates away leaving just the solids. Normaly expressed in lbs per gallon (gm per ltr) or as a percentage of total "wet" weight.
For what it is worth, paint, welds, and fastenings account for 5-7% of the total lightship weight of a steel ship. Not sure about the precentage for a wood or composite hull, but I'd guess 2-4% of lightship based upon the weight of the bottom paint I used to put on my Ranger 26.
To paint or not to paint over 3m 5200 BurnabyRocket61 Materials 3 09-01-2008 08:45 PM
Paint weight rturbett Fiberglass and Composite Boat Building 4 04-03-2008 09:01 AM
Weight balance. Will it ride better with weight in the rear or dead center? clctrader Boat Design 4 01-24-2008 12:12 AM
wet weight vs dry weight of Diesels... spank Boat Design 3 10-20-2006 03:16 AM
Average Human Weight, Safe Excess Weight, &c. Free Pirate Boat Design 12 03-14-2005 01:40 AM
