Old 11-10-2001, 05:24 PM
Memphis Mike Memphis Mike is offline
Rep: 10 Posts: 4
water over the transom on Diablo
I have found the only problem with my Diablo so far. At higher speeds she churns up water over the transom in the middle
where the motor bracket is. I have determined the cause to be
the long shaft motor.
Although the plans call for a long shaft, the 2001 25 Merc that I have sits about 4 inches too low in the water. Has anyone experienced anything similar and if so what was done to correct it?
Old 01-18-2004, 10:04 AM
Unregistered
Water over transom
I had the same problem with a 25hp long shaft Merc outboard on my Diablo boat. I epoxied in a built up plywood piece to raise the transom height and thus the motor. No problems now with water over the transom, even at top speed.
The outboard motor's cavitation plate and attached "Dolphin" fin are now even with the bottom of the hull.
How about boat design definitions JonathanCole Boat Design 55 01-24-2010 04:48 PM
epoxy fuel tanks Boatbuilding 24 08-14-2008 03:36 AM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
Building a heat exchanger into the hull djackson99 Powerboats 42 03-21-2005 02:15 PM
Water soaked transom paintacar Fiberglass and Composite Boat Building 2 06-08-2004 04:29 PM
