| Warehouse or Tent for Building a Boat? I have two options for building right now - warehouse or tent. Both are exactly the same amount of money (ok, the tent is about $4000 more). Everything else is equivalent. These build locations are in FL and it's going to be hotter than I am used to down there. Would you choose a warehouse to build in or a tent to build in? Why would you choose one vs the other? Thanks! |
| warehouse- less chance a big storm gets in than a tent. it's always nice to have a solid roof and walls to prop things against as well. |
| HI catbuilder, my freind John built this tent, one wall is shipping containers, the others secondhand roofing, the roof is fabric & been through 125 kmh winds(disconcerting at the time) & now at about 10-12 years old is pretty weary, I built tooling for my cat in it but I doubt if our local surveying authority would like it for composite vessel construction, all the best with your endeavours from Jeff. Last edited by waikikin : 04-22-2010 at 01:49 AM. Reason: more words |
| Go for the warehouse as you have a better chance at controlling climate conditions. The biggest mistake I have made with my project is only having erected a barn style shed. No concrete floor and only side walls, ends are only closed off with shade cloth curtains. I am building a foam, glass & epoxy catamaran and bore I started I had aspirations of putting in 60hr week. Although I knew that Brisbane is relatively humid I assumed that the shed would be OK to build in as there were plenty of local builders doing like wise. It was only after I started building and got a humidity meter I discovered how bad the humidity was. So instead of being able to put in 60 hr week I am lucky to average 20 productive hours per week. This is going to turn out to be a very long build, luckily for me the build is just as important as the sailing. |
| I started in a tent structure but the county building officials gave my landlord a bit of grief so I ended up moving into an adjacent barn. I don't have the humidity problem so I can't weigh in on that topic, but I much prefer the barn. I would definately opt for the warehouse as I assume it has a concrete floor. My barn does not and keeping the dirt out of work areas is a bit of extra work. One issue is blowing dust and dirt. The more enclosed your work area, the better off you'll be in this respect. The downside to a tight building is proper ventilation when you need it. |
| Good advice. Thank you, everyone. I'll go for the warehouse. |
| My vote.. i would go for the warehouse as well.. Hands down..
__________________ Capt. John Banister, Marine Surveyor Palm Beach Gardens, Florida www.SuenosAzules.com |
| Ok, things have really progressed this week. I am again in need of some expert opinions from people who have been there and done that. I am back to the "do I build in a tent or a warehouse?" Why? I have several marinas now that would like a free $7000 tent up North, close to my wife, as well as a warehouse building that is ready for lease signing. I need to choose between the two options, but don't have enough building experience to know. Factors include building ease and quality as well as cost. Let's take a look: The tent is this one. I guess it's more properly called a "fabric building." It's $7000 and has a 15 year warranty. ![]() ![]() The warehouse looks something like this and has an overhead crane, as pictured: ![]() Those are the two types of buildings I can build in. Here's a summary of costs: Tent
Warehouse
| Only you can answer this question and only you should. Do a pro / con sheet and assign value figures to each point. Add each column and the higher number column wins. It's easy and very effective. Good luck! -Tom |
| I'm not sure if I'm understanding the costs correctly. I assume the extra $6k noted for the warehouse items is in addition to "total costs"? I'm also assuming that both options have a concrete floor. In any case, here are some things to think about. The $4k to open up the building could be problematic. You only have 1 ft. clearance on each side which may involve removal of critical structural elements in the front of the building. I could see this cost escalating. In either case, you want to check out overhead clearance once the boat is on a trailer. I'm an inch overheight to get out of my doorway which may involve some work on the building. Anyway, be sure you've got this figured out. The thing that worries me about both spaces is the tightness around the sides. I suppose that you may be able to walk between the hulls for some period of time, but at some point there is going to be an issue. On thing I did in my space that is really working well is that I build a 25'x20' shop platform at the back of the barn that is raised about 6 ft. I can step right off of this deck onto the transom (at waterline). I learned from the last time I did this that it is really a pita to have to climb out and over and back again each time you need something. Could you do something like this at the front of the "tent"? You'd need to build it so that it could easily be dismantled, but it might also provide needed storage below. (I find this area extremely useful in my setup) The crane would be handy, but not critical in my opinion. All in all, I think I'd be leaning toward the fabric structure because of the width and costs. And since you are purchasing the tent new, I'd suggest seeing if you can get it just a tad bit larger in both dimensions. Regards, SeaJay |
The tent is cheaper, but I also have to come up with flooring - level flooring. I will also have no security, since you can break in with a utility knife. There will be differences in climate control. There are a lot of differences between the two and of course, the warehouse is better. However, it costs nearly twice as much at year two because it's rented. What I don't know is if this doubling in price will really save me money in the long run because it's so much better to build a boat in a warehouse. This question can't be answered by pros and cons because it's weighted with money and also with people's experiences building in each type of structure, which I have none of. |
| Good point. My costs were written a little poorly. The total costs are totals *including* all of the extras for modifying the warehouse. I just broke them out to show what they were. Sorry if that was confusing. I have 27' inside the building inside the structural columns. The boat will come out, no problem, with 1' on either side. There is one structural column to remove, but the whole building is bolted together. You unscrew this or that and take a piece off. The exterior is sheet metal. It's modular, and everything has already been measured. My overhead clearance is quite low because I have no keel. 15' max, the building is something like 20-25' tall. The measuring has all been done. I think the tightness around the sides is going to be a huge PITA when it comes time for Awlgrip. Maybe I can paint athwartships before I put the hulls into place? Definitely that will be a huge issue and I haven't 100% solved it yet. Thanks for the input. I'll think hard about the fabric structure and platform. Good idea there. Quote:
| Check out this Cat Builder's website...somewhere I think there is a photo of a working platform that he has at one end of the boat. http://scrumbleproject.wordpress.com/table-of-contents/ |
| It seems that cost is an very important factor in this choice. So, how do the costs escalate for both options when you do not meet your planned for schedule? |
| look around everywhere very very seldom does a project like this finish on time go for the cheapest the costs escalate soooo much anyway that you will **** yourself at the end be warned - the 2 years will EASY EASY become 3
__________________ Bye bye Folks - off to see the world ~~~/)~~~ :) Compulsive Neurotic Manic Depressive, but basically happy :) http://compaxboats.wordpress.com/ http://www.boatdesign.net/forums/boa...ser-27869.html |
| boatbuilding/warehouse job | JR-Shine | Services & Employment | 0 | 02-12-2007 11:37 AM |
| Newbie to boat design and building wants to make own boat | bigisland | Boat Design | 2 | 01-20-2007 12:03 AM |
| boat building UK | Jurach | Education | 0 | 03-24-2006 01:24 PM |
| PT Boat building/warehouse man needed | JR-Shine | Services & Employment | 0 | 12-19-2005 03:07 PM |
| Help!!! Building a new Boat!!!! | Hannibal221 | Wooden Boat Building and Restoration | 6 | 06-23-2005 09:31 AM |
