Old 05-29-2009, 10:13 PM
pongorulz pongorulz is offline
Rep: 10 Posts: 3
wanting a jet drive boat
i was recently given a ford 302 and decided to build a boat for it. but i want a jet drive boat, i have always had so much fun in jet drives. anyways i cant seem to find a hull for it. everywhere i look on line everybody has these little rooster tail boats and that not what im looking for. im looking for something like a seadoo or yahama jet boat, something like 20 feet or so so that my buddies and i can do some wake boarding and what not.
so since i cant find a "jet drive hull" i was wondering if its possible to just use a inboard hull, since they have those plates mounted to transom
and is a 302 a big enough engine for this idea
Old 05-29-2009, 10:33 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,691
pongorulz
You're putting the cart before the horse. To do it properly, you need to select/'design' a boat that suits your requirements other than you have been given a Ford 302! Design/select the type of boat you want, ie what length, beam, draft, outfit etc things "you would like" from your boat, then design/select one that satisfies those requirements. Once you have that, then you can see whether your Ford 302 will be suitable or not.
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
Simple jet drive for small boat tom kane Jet Drives 2 04-01-2007 09:20 PM
jet boat drive shaft bearring sandrail Jet Drives 5 06-30-2006 06:41 PM
inflatable boat with jet drive - is that possible? DRY_GIN Boat Design 12 04-05-2006 09:46 PM
exhaust on a jet drive boat jetboatjill Open Discussion: All Things Boats & Boating 0 04-08-2005 06:54 PM
