Old 08-28-2011, 08:05 AM
inspirations inspirations is offline
want to build a boat?
I am building a boat for the first time i want to know about the requirement of material to be used?
http://www.danishinspirations.com/modern-and-contemporary-furniture-guadalajara-mexico/
http://www.danishinspirations.com/modern-and-contemporary-furniture-serving-tyler-texas/
Old 08-28-2011, 08:59 AM
Dirteater's Avatar
Dirteater Dirteater is offline
Rep: 187 Posts: 151
Hi Inspire,
Your question is certainly a good one and very recently (couple years)
I asked my self the very same question. But there's a few question
I needed to answer first. ie: what kind of boat do you want to build?,
where do I plan on using it? and what is your budget? what's is your
inspiration? From here you can start to decide on your materials.
Personally I found the planning as much fun as the actual building.
It,s a pretty big task in itself. when all was said and done I built a boat
that is very much custom to my answers to the above questions.
Material wise (for me) it was: Marine plywood, epoxy and fiber. Of course
everybody's boat is going to be different. I have finished my boat to the rowing stage and there is still work to be done regarding the sailing aspect and some other odds and ends I have yet to finish.
It is a wonderful experience and I wish you every success.
I hope this helps to clarify some of your question. We need a little
more detail of what you would like to build before one can answer your
question regarding materials. I am indeed a junior member/builder (I'm 50+ though *L*) There are members in this forum that are very helpful with much more experience than I will every have. so... as your questions become more detailed, the members will be able to offer more advise. ( I did find myself "hitting the books" a lot).
regards
DE
thinking about putting tholes in my boat.
Old 09-02-2011, 02:18 AM
m3mm0s rib's Avatar
m3mm0s rib m3mm0s rib is offline
Rep: 31 Posts: 111
I am also a new member and try to finish that began two years ago. Sure do not we make the same object, but our concerns are the same. I believe that we will succeed. If I can help you with something Ask me good continuity http://www.youtube.com/watch?v=5kwlNk7-iSg
m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg
Can I (should I) build this boat this way fred breyer Fiberglass and Composite Boat Building 7 02-07-2010 03:23 AM
settled on a boat to build can i put a junk sail on this boat? Trevornew Sailboats 7 04-11-2009 06:25 PM
First Boat build kilted1 Sailboats 19 03-29-2009 01:30 PM
Help me build my first boat! Please MisterSteve124 Projects & Proposals 15 08-05-2007 03:07 PM
Help me to Build a Boat sharkfish Boat Design 6 05-31-2007 05:22 PM
