Old 09-23-2008, 08:33 PM
BSR001 BSR001 is offline
Rep: 10 Posts: 6
Vaccume baggin advice
Im building freestyle jetski hulls and im looking into vaccume bagging.however i have a few questions.right now my layup scheadule is where im happy with it.my question is if i do the same layup and bag it im gonna loose some of my thickness.does that mean i also loose the rigidity of the part do to it being thinner or will it not be enough to notice.
Also is polyester or vinylester resing baggable.thanks
here is a few pics of my hulls
Old 09-24-2008, 12:59 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,050
Basicly getting rid of excess resin increases strength. About rigidity not sure..
Old 09-24-2008, 04:50 PM
Previous Member
Rep: 0 Posts: 0
Panel rigidity is a function of the elastic modulus of the glass used and the thickness to the third power. So thickness is extremely important for gaining rigidity. If you are effectively using excess resin as a filler to increase thickness then you gain in rigidity for the amount of glass used.
This is not the most effective way to gain rigidity because there are much lower density fillers but making a cored panel is a more complicated layup particularly if it is a complex shape.
If you vacuum bag to reduce excess resin in the same glass schedule you should expect that the strength will be the same, the weight a little less and the panels considerably more flexible. The latter may be undesirable.
Rick W
Advice Dani Wooden Boat Building and Restoration 2 05-07-2008 06:07 AM
Looking for some advice please Emmenel Wooden Boat Building and Restoration 5 05-02-2008 08:04 PM
vacume baggin Help!! blasterboy1980 Fiberglass and Composite Boat Building 0 10-29-2006 07:30 PM
Advice Jdub Education 0 01-10-2006 11:15 PM
Advice welcome Markil Wooden Boat Building and Restoration 8 07-13-2005 09:51 PM
