| PAR - yes, you can disable the blade-stop feature on the Sawstop. There's a manual override to use if you're cutting aluminum or other conductive material. The saw can be returned to service after it trips; this involves replacing the blade, the brake block and the fusible link that holds the brake block in place. (And re-compressing the friggin' big spring that drives the block into the blade.) Not sure how much this costs, but probably a couple hundred bucks or so to put it back in service. My main concern with it would be that the system does involve a DSP (digital signal processing) chip to decide when the electric charge on the blade has dropped quickly enough to trip the stop mechanism. I have a hard time trusting computerized stuff, and I would certainly not ease up on normal safety precautions as a result. (Indeed, I would probably not even tell anyone using the saw that it had the self-stop feature.)
| Wow. What some people will do to make a sale! Things do malfunction once in a while. I wouldn't hjave done it for love or money! |
| impressive metal boats | lazeyjack | Metal Boat Building | 31 | 07-22-2009 03:51 PM |
| Is my boat safe? | RoyalStar | Stability | 12 | 01-16-2008 02:56 AM |
| River cruising is safe... right? | cac | Open Discussion: All Things Boats & Boating | 21 | 10-27-2006 04:12 PM |
| Safe Engine Removal | Texas Boater | Wooden Boat Building and Restoration | 7 | 05-11-2006 04:10 PM |
| Safe Remote Fuel System for boats | tom kane | Open Discussion: All Things Boats & Boating | 7 | 04-04-2005 10:36 PM |
