Old 08-10-2003, 08:01 AM
jetkibby jetkibby is offline
Rep: 10 Posts: 2
v-drive propulsion question
Hey,
Been practicing my welding and want to construct a aluminium offshore powerboat 6-7 meters that can go places for adventure uses. Kind of like this one.
http://www.alucraftboats.com.au/Leis.../leisure16.htm
The biggest problem i and my associates (dad and brothers) is propultion unlike many of the super rich people i cannot afford a new outboard or second hand twin outbaords.
This is when i looked to the deep recesses of the shed and found a pretty big brand new V-8 chevy (220 kw) that we were going to put in a race car we can easily marinise or install a heat exchanger on.
Upon this discovery i was quick to the internet to look up kinds of propultion seeing the prices of reconditions sterndrives it seems the best bet to go for a v-drive inboard so we can sit the motor down the back of it.
This is where i require the help i cant find a single design from all the kit producers which is for a v-drive. can anyone point me in the direction of a design for a offshore inboard speedboat V-drive if possible.
Or if you have any ideas on how to make a v- drive housing for a boat it would make life alot easier. even if you have a idea for a good reliable form of propultion that wont hit the pocket too hard.
struth i've just about told my life story, any help would be nice.
Cheers,
J.K
Old 08-11-2003, 11:53 AM
Rep: 1397 Posts: 7,216
Marine engines have a few differences with automotive: camshaft, bronze freeze plugs, stainless gaskets, high volume oil pump among others. Also, blocks and heads cast for marine applications have nickel content to make them corrosion resistant. If you have a closed cooling system it will solve some problems. V drives are more expensive and complicated than a straight inboard. They involve two gear housings. If you are on a budget, just one transmission will be cheaper. However, between a transmission, shaft, struts, rudder, etc. and a sterndrive unit, the cost is about equal.
Velvet Drive Question DOGGYDOO DIY Marinizing 13 11-10-2005 11:30 PM
drive options; vee, stern, jet curtis73 Powerboats 5 08-07-2005 09:29 PM
Power choice Poll duluthboats Option One 154 07-18-2005 02:24 PM
Wormhole Drive Propulsion!. trouty Boat Design 31 06-13-2005 11:51 PM
Jet drive question. PHamann Boat Design 2 08-21-2004 04:50 PM
