| V Drive alternative? Hi
Does anyone know of a transmission/ drive system that works like a V drive but has the input shaft and output shaft parallel where the prop shaft goes directly under the engine?
We're currently using a Hurth 630 V drive but we would like to mount the engine at the same angle as the prop shaft. It could be a crunch box or maybe not even have reverse. We thought about fabricating a belt drive system but were worried about the absense of side load bearings and the pressure put on the system by the thrust of the prop. Any ideas welcome. Thanks
Rob Innes
INNESPACE
