Old 10-08-2009, 04:32 AM
Jessicajil Jessicajil is offline
Using polystyrene as float/pontoon for a houseboat
The houseboat is going to sit on tidal mud in a river estuary, floating mainly on the highest tides. It will be moored using fixed posts (spud lugs) so that there will be very little lateral movement. The proposal is to build a 2 storey plywood houseboat on a 80cm polystyrene float sheathed at the side to protect it from lateral damage and fire.
Does anyone have any experience of doing this?
Old 10-08-2009, 05:06 AM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
Expanded polystyrene will initially float on top of the water's surface, but if in permanent contact with water it has a tendency to absorb water very slowly (over a period of weeks) until it becomes waterlogged, at which time it may either float just at the surface or slowly sink.
If you want to use foam you need to use closed cell foam.
On your scale that could be quite expensive, and surprisingly heavy if they are solid blocks.
Best to buy or make hollow floats of plywood / epoxy , or poly urethane closed cell foam ,Polycore honeycomb panels , steel , even concrete modules similar to those used for marina docks etc.
Float Plane Pontoon Trimaran Boat Scotty Wisley Boat Design 0 05-01-2009 02:21 AM
pontoon houseboat questions doingitmyway Boat Design 5 03-04-2008 09:07 PM
Houseboat pontoon jansenpg1 Boat Design 24 11-19-2007 04:02 AM
Houseboat Pontoon Design Jaguar Metal Boat Building 8 09-28-2004 04:45 PM
center pontoon on houseboat hboat Boat Design 0 05-05-2004 10:16 PM
