Old 02-05-2007, 05:19 PM
WarrenW WarrenW is offline
Rep: 10 Posts: 12
Using epoxy and fasteners for frames - question
I have been reading the epoxy information for Poxy Grip which I have for building my frames. As I have read in the forums, it also states not to clamp the parts tight - just tight enough to imobilize them.
My question is if I use fasteners on the frames also, won't they pull the gussets to the frames so tight it squeezes the epoxy out? Or are people just glueing the gussets on with clamps and then adding fasteners after its dry as extra holding?
Just wanted to make sure I do it right since I'm ready to start assembling my frames. I bought Poxy Grip for the frames but plan to buy Poxy Shield as well for coating parts, etc.
Warren
Old 02-06-2007, 08:27 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
No tight clamping with epoxy. In general we do not use any mechanical fasteners, but if we do they are put in after the part is set in epoxy. Sometimes I use dry wall screws to hold something while the epoxy sets, when I do I screw it tight, then back off so that the epoxy glue is not pushed out. Remove the screws when the epoxy has partially cured.
www.boatbuildercentral.com
Old 02-10-2007, 01:46 AM
Rep: 3125 Posts: 9,395
Ditto, epoxy needs a little slop to work. I use drywall screws too, but set the drill's clutch to the lowest setting, so the head just makes contact, before the clutch engages. Bring the gussets in contact with your frame pieces, until you see goo oozing out from each seam, that's all you need as far as clamping pressure.
Newby question regarding Epoxy and fiberglass redecking and plywood choices baranx4 Boatbuilding 3 03-05-2007 07:55 AM
Fasteners as well as epoxy at sheer/deck joint? bjl_sailor Wooden Boat Building and Restoration 3 05-26-2005 07:47 PM
epoxy question, zember311 Boatbuilding 5 05-23-2005 11:38 AM
Paint question over epoxy zember311 Boatbuilding 5 11-26-2004 02:22 PM
Fasteners Materials 1 01-24-2003 06:37 PM
