Old 04-18-2011, 04:09 AM
barrow_matt barrow_matt is offline
Rep: 10 Posts: 9
UK Builders - Which adhesive for stitch and glue
I would like to know if anyone in the UK could recommend an adhesive for a small ply stitch and glue construction?
I've looked on the likes of Screwfix and Toolstation and can't see any bulk general purpose epoxy, is it called something else here or am I looking in the wrong place.
Typical fibreglass supplies seem to use Polymer Resin, is this different from an epoxy or the same thing. I'm sure this may be ok to seal a seam but i'm nnot sure it is strong enough to act as a structural adhesive?
Thanks.
Old 04-18-2011, 07:08 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
www.cfsnet.co.uk ,advice and materials
Old 04-20-2011, 10:20 AM
Jeremy Harris's Avatar
Jeremy Harris Jeremy Harris is offline
Rep: 592 Posts: 692
Generally, I've found that I can only buy epoxy at specialist places, not run-of-the-mill DIY stores.
CFS, as suggested already, are a good online supplier of West System, but you may find somewhere more local to you. I'm lucky, I'm a 20 minute drive away from Wessex Resins, the West System stockist (http://www.wessex-resins.com/) and maybe 40 minutes away from a number of stockists of other epoxy resins, like SP.
I've used both West and SP and slightly prefer West, plus it doesn't really smell (the SP stuff does have a slight smell).
You can build a stitch and glue boat using polyester resin, there are thousands of Mirror dinghy's around that were built this way many years ago. Polyester is cheaper, nasty to work with, very smelly and doesn't bond all that well to wood (unless the wood is very dry) as epoxy.
Personally I'd use West System epoxy. Remember that you'll need more than just the resin and hardener, you'll also need glass fibre tape and some microfibre to stiffen the resin into paste for filleting. If you want to fair the hull after taping, then I'd recommend using some West Microlight 410 filler as fairing compound, as it's nicer to use than body filler and sands more easily to a good finish.
Jeremy
Stitch and Glue? stonedpirate Boatbuilding 8 12-06-2009 09:46 PM
stitch n glue Pelican? Phildave Boat Design 0 02-04-2009 06:32 AM
stitch and glue? kayakn Wooden Boat Building and Restoration 4 07-21-2008 11:08 PM
26' stitch and glue regal Boat Design 5 07-09-2004 12:10 PM
stitch and glue Boatbuilding 2 06-27-2002 08:33 PM
