Old 10-06-2002, 02:56 PM
big cat big cat is offline
Rep: 10 Posts: 11
U V curing
Has anyone had experence using ultra-violet curing using foam sandwitch construction?
Bob
Old 10-07-2002, 11:05 PM
8knots 8knots is offline
A little on the slow side
Rep: 349 Posts: 266
lay-up needds to be translucent
From the stuff I have read and heard from the manufacturers. The light must be able to penatrate the laminate. Mark Livesay...
I think that is the guy from Sunrez????? We spoke on using 1-2mm Coremat (made by the Nida-core people) in my laminate schedual for the sea kayaks I am playing with.He was a bit leary.
I have heard most people use standard catylized resin in a dry bag set-up You could maybe try researching this method.....
1) Shoot your gel coat, let cure the right amout of time based on your conditions.
2)Do a skin coat using the UV resin system.
3)Bed Your core material in a catylized resin or thickened epoxy
and bag to the skin coat.
4)Bag your inner skin to the core using the UV system
I think this is the way I would try to go. WARNING!!!!SPECULATION...............................................................
I abandoned the uv for my kayaks because the light would not penetrate the Carbon fiber I need to use.
and I could not utilize a silicone reusable vacuum bag.
I don't know if this will help at all, But UV is an expensive Experiment! Good Luck 8Kts
Old 10-08-2002, 09:13 AM
Rep: 10 Posts: 11
Thanks 8knts
Old 10-09-2002, 02:04 PM
Rep: 10 Posts: 11
Hi 8Knts.
just spoke with sunrez & you're correct using uv the foam must be glued in as the uv won't penetrate the foam.
Vinylester question Materials 42 01-30-2006 09:29 AM
fiberglass molding Fiberglass and Composite Boat Building 9 08-17-2005 03:56 PM
Help with Print-through Problem In The Hull genuineyachts Fiberglass and Composite Boat Building 18 09-23-2004 12:08 PM
