Old 02-16-2010, 05:06 AM
elhix elhix is offline
Rep: 10 Posts: 13
U-bolt fitting - bedding threads in epoxy
My plans include u-bolts for a bridle at the bows. They have their threads embedded in epoxy in a hardwood block that is in turn behind several layers of glass. I have added a similar feature to the two sterns for a drogue bridle.
My question is: does embedding u-bolt threads is epoxy provide the strength necessary?
Old 02-16-2010, 10:44 AM
Rep: 1758 Posts: 1,561
Get a copy of "The Gougeon Brothers on Boat Construction" book. It has an extensive discussion of how to design an epoxy only fitting like that: required hole size, hole depth, strength, etc.
Old 02-16-2010, 02:19 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
IF the joint was designed and built properly it should hold up just fine. If there is some reason to think this joint will fail? Is there a history of this joint failing? OR are you not confident you can built it properly?
It can also be more durable than a bolted joint, where it can trap moisture and allow rot in a place that is hard to inspect.
Old 02-17-2010, 01:32 PM
Rep: 10 Posts: 13
I've no reason to believe the joint as described on the plans will fail and certainly feel happy to build it, I was just looking for opinion on this type of fitting rather than the usual bolts and backing plates.
Jehardiman, I should have bought the Gougeons book back in the beginning... I'm reluctant to now as it'll only tell me what I could have done better. Going to have a look on amazon though.
Old 02-17-2010, 04:48 PM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,840
I would certainly not consider the threads in epoxy to have the same strength as a backing plate...but the fact that you are only using this system for the bridle ends...you should be able to get away with it for a long time. The fastening is stronger than the rope and the rope will absorb shocks in the system so you should be ok.
Hi-Jacking threads gonzo Forum Questions and Suggestions 111 02-16-2010 03:27 PM
Piggyback: Bilge Keel threads lewisboats Sailboats 6 07-28-2009 12:44 PM
Classing Societies etc Threads Willallison Forum Questions and Suggestions 4 10-03-2007 06:56 AM
misplaced threads gonzo Forum Questions and Suggestions 3 06-28-2006 05:59 PM
Lost threads and replies DSmith Sailboats 4 04-18-2006 09:28 PM
