| Treated wood and epoxy I have read that epoxy doesn't bond well with treated wood. How poorly does it bond? Is it just a minor "weakening" of the joint? Is it that the various chemicals "don't get along"? I have come into the free possesion of a piece of Southern Yellow Pine which is rift sawn and is 2x12x 20'. Unfortunately it is treated wood. Should I run from it or can I use it for the bottom portion of my frames. Sure do hate to just not use it, but I will, if I can't trust epoxy to bond sufficiently. Thanks much for your expertise! |
| How has been treated the wood? what product? A part ethyleneglycol diluted with water, I'm not confident of other products. I made crude tests with CCA treated wood and the results were very bad. It seems that the mix of metals interferes with the gluing. If you encapsulate all the wood with epoxy, a desinfection with monoethylene is enough, as epoxy will prevent later infection. If you plan to glue with epoxy, but not to encapsulate; the fate in marine environment will be failure of the glue joints after a few cycles of wetting-drying even if the wood has been protected with paints. Resorcine works better in this case. |
| Wood/Epoxy Keel and Keelson | CanuckGuy | Wooden Boat Building and Restoration | 34 | 09-11-2008 03:11 AM |
| Epoxy instead of wood possible? | Vhull | Fiberglass and Composite Boat Building | 1 | 07-12-2006 06:55 PM |
| Epoxy to use on wood? | JoseSanchez | Materials | 4 | 05-17-2006 12:13 AM |
| glass/epoxy over wood | jomo | Boat Design | 4 | 11-22-2005 10:54 AM |
| Epoxy and pressure treated wood | ted655 | Materials | 2 | 07-20-2005 06:52 PM |
