Old 12-22-2002, 10:30 AM
Baz Baz is offline
Rep: 10 Posts: 11
Transom Scantling
I'm design a 16 ft fiberglass boat but I cant find any information anywhere on Scantling rules for building a strong transom for an outboard engine. The transom is 42 in wide, the max outboard rating would be 40 HP. Does anyone know of any links to go to?
Any information would be greatly appreciated. Thanks
Old 01-24-2003, 07:24 PM
Rep: 1397 Posts: 7,215
The outboards, regardless of horsepower, are designed for a transom of aproximately 3/4". The usual construction is with two layers of 3/4" plywood covered in fiberglass. I/O's are designed assuming the same transom thickness.
Old 01-25-2003, 08:05 AM
Baz Baz is offline
Rep: 10 Posts: 11
Transom Thickness
thank you for your response but I am still a bit confused on the final thickness. Is the final thickness (3/4+3/4= 1.5"thick + FRP) or layers of plywood adding up to a final thickness of 3/4. What about the fibrglass? Sould it be as thick as the bottom or the Basic Shell thickness ?
Thanks
Old 01-25-2003, 03:30 PM
Sorry about the mlsprint. The final thickness is about 1 3/4". Laminate the inside with two layers of .75oz mat or one of 1708 stich mat. On the outside the laminate should be equal to the sides.
Old 01-26-2003, 06:14 PM
Baz Baz is offline
Rep: 10 Posts: 11
Thanks
thanks for the info.
Transom Bracket on a 19ft boat CapeCodder Powerboats 6 12-07-2011 10:30 AM
BassBoat Drain area, below transom rot HELP!! northrivergeek Powerboats 4 12-12-2005 08:06 AM
Attaching stringers to transom? mikkyle Fiberglass and Composite Boat Building 3 12-13-2004 03:21 AM
plywood rotting in transom - grp boat brian c Fiberglass and Composite Boat Building 2 10-07-2004 06:54 PM
Composite Question, filling transom holes foca Powerboats 5 07-10-2004 12:46 AM
