Old 02-16-2009, 03:37 PM
renovatio renovatio is offline
Rep: 10 Posts: 19
Transom repair
I thought that I would post this project that did 2 years ago. This boat had some sentimental value and I probably put more money into then it was worth but it did turn out pretty good. I used Seacast to do the transom and from what I've read is somewhat controversial here on this site. However the end result was a transom that I feel will last a lot longer then the wood repair that had been done just three years earlier at a boat repair yard.
transom-repair-cngseas2.jpg  transom-repair-cngseas4.jpg  transom-repair-cngseas3.jpg
transom-repair-cngseas7.jpg  transom-repair-cngseas5.jpg  transom-repair-cngseas6.jpg
Old 06-15-2009, 01:50 PM
fastrex fastrex is offline
transom repair
Is that a Larson?
I have a 1975 tri-hull that i have to fix and have been debating the best way to go. Did you have an inner skin of fiberglass originally or was it just the wood?
Looks good.
Old 06-21-2009, 03:28 AM
Rep: 10 Posts: 19
No, it's not a Larson Thats a Gastex Seastar. I don't think that they are in business any longer. I sold the boat to my uncle, and the transom has held up well so far. There was an inner skin of glass and a 2X4 stuffed in behind it. The yard that did the repair boosted that transom will handle a black max 250 no problem, yeah right. severe b.s. the thing almost fell off in lake Powell with a Chrysler 115 on it. When I took the top cap off there was another skin jammed in with the mess that it was pretty said. The whole seacast system seemed to make a lot of since to me. There is more than one way to go about it. Good luck with your project.
Old 07-09-2009, 10:56 AM
thill thill is offline
Rep: 10 Posts: 26
Looks like you were careful with your workmanship and did a good job. I also did a Seacast reapair, (using both older skins as a form without cutting them off) and mine has been solid for a couple of years so far.
Let us know how it lasts. Time tells everything. I've committed to posting about the results as long as I can. You never know, it might last forever or it might fail after time, but I'd like to know either way.
-TH
transom repair cflood Boatbuilding 9 07-09-2009 11:02 AM
71 IMP Transom Repair 71ImpSantee Powerboats 3 07-11-2008 11:54 PM
Transom Repair dblanton Outboards 0 10-22-2007 08:31 AM
Transom Repair for '73 Ranger mkimler Boat Design 5 08-31-2007 02:54 AM
transom repair andrew Fiberglass and Composite Boat Building 4 01-25-2005 10:38 PM
