Old 07-30-2007, 03:52 PM
cflood cflood is offline
transom repair
I was hoping someone could give me some advice about repairing my transom.
I own a 1968 crown line fiberglass 16'. The transom is rotting but it's not completly gone yet. I was considering using 3/4 cabnet grade plywood to put on as another layer to sure it up. I would re-fiberglass it and use stainless carriage bolts and washers to tie it all back in.
My question is, would this work and would it be strong enough for a 30-50 hp outboard. I'm looking to repair it cheaply since I got the boat for free. It is my first boat and would appreciate any advice other than completly replacing the transom which I know would be a lot of money.
Old 07-30-2007, 05:45 PM
charmc charmc is offline
Rep: 779 Posts: 2,387
Transom repair discussed before
Try searching (upper right corner) for transom repair or transom replacement in the forums. There have been several discussions of cost effective techniques, including photos and links to photos of works in progress. Your best bet will probably be to cut and grind away the inner fiberglass and all of the rotted wood, but leaving the outer fiberglass transom intact. Then you can bond your replacement plywood to the inside surface of the fiberglass transom, reinforce and bond to the remainder of the hull, and glass in the whole thing. The earlier discussions include detailed instructions for each step of the work. You need to cut away all the rotted wood and replace it, rather than glassing something to reinforce it. The cost is more your time, not much more materials cost, but it's imperative to do it right. Rot is an attack on wood by microorganisms; it will continue and spread to other areas unless the affected wood is removed. I think 3/4" will be sufficient for a 16' outboard, but check with the people who have done this before.
Good luck with your project!
Best,
Charlie
Old 07-30-2007, 05:58 PM
jigerbetter jigerbetter is offline
Rep: 10 Posts: 4
good advice
I think charmc gave you good advice.
to do correctly is pretty technical good luck !!!!!
Old 07-30-2007, 06:19 PM
SamSam SamSam is offline
Rep: 222 Posts: 1,132
I have a 15 1/2' tri-hull i bought in '93. I assume the transom was rotted then because it had aluminum plates on it. I know it's rotted now as I occasionally have to knock fungoidal mushroom growths off of it. I've always had a 40 hp Yamaha on it and have never had any worries about the safety of it, but possibly I'm just being stupid. The plates are 22" wide, the outside one being 15" tall and the inside one 6" tall, being shorter because of the splashwell. They both have a 1 1/2" lip bent in at the top, so at the top of the transom they sit on top of each other and form a double layer. The thickness is over 1/8 but less than 3/16", whatever gauge that might be. The top motor mount bolts bolt the two plates together, sandwich like, and below the splashwell the lower motor bolts just have big washers on the inside. Another chunk of plate or a piece of angle would have been allright, too. Around the edge small screws hold them generally in place.
Old 07-30-2007, 07:30 PM
Catsailor's Avatar
Catsailor Catsailor is offline
Boatbuilder & sailor
Rep: 21 Posts: 9
See "hull & deck" on the website www.handymariner.com.au/ There are articles and pictures of repairs. Charmc is right - cut out all of the rot area, then bond in either a foam or ply patch, glass over the lot, fill and fair it. If you work carefully and systematically, the result will be stronger than the original boat and completely invisible
Cheers
Alan
Old 08-01-2007, 01:25 AM
Rep: 1133 Posts: 4,714
Outboard powered small craft, have pretty much accepted a transom thickness standard as 1 1/2", which typically is two layers of 3/4" plywood, bonded to the hull shell. Cabinet grade plywood will not do (panel construction issues) and likely will not have WBP adhesive also, which makes this a very poor choice for a transom. There are a number of ways you can approach this problem and many previous threads have covered the subjects involved well.
Old 08-02-2007, 04:24 AM
Loveofsea Loveofsea is offline
Rep: 58 Posts: 78
don't ever use anything but marine plywood in a boat--
because the original manufacturer didn't use marine grade wood is exactly why you are having to replace the existing wood...
Old 08-02-2007, 07:21 PM
Catsailor's Avatar
Rep: 21 Posts: 9
Sorry to disagree, but the only difference between "marine" and "construction-grade exterior" ply is the face veneers. The thing to look for is the bonding - namely boilproof - specifically Moisture Resistant Waterproof Structural Panel "technical" grade or at worst - Type I
If you are going to glass over it, why pay the extra money for expensive face veneers?
Old 12-18-2008, 12:38 PM
boatman2 boatman2 is offline
Check into seacast. It works.
Old 07-09-2009, 11:02 AM
thill thill is offline
Rep: 10 Posts: 26
If you are going to plywood and epoxy, make sure to get the right materials and do your research, so you do it right, and don't just waste your money.
Seacast might work well for you, but again, you must use the proper materials, and follow the instructions. Don't skimp on the glass, as that's where the majority of strength is.
Either way, make sure to get ALL the rot out before attempting to repair.
Best wishes!
-TH
transom repair advice CIG29 Fiberglass and Composite Boat Building 17 11-23-2006 09:28 PM
Transom repair question robbieinga Open Discussion 5 08-27-2006 05:55 PM
Transom Repair with Coosa IHTFP Fiberglass and Composite Boat Building 0 10-06-2005 08:15 PM
transom repair andrew Fiberglass and Composite Boat Building 4 01-25-2005 10:38 PM
transom repair/replacement? ldolbee Fiberglass and Composite Boat Building 5 01-13-2005 11:27 AM
