Old 06-17-2006, 02:16 PM
shelbygone shelbygone is offline
Rep: 10 Posts: 10
transom
ok guys, what would you use to apply new plywood to the fiberglass tansom? also what do you think about using poplar wood in a boat,floor,transom?(plywood,boards)?
Old 06-17-2006, 11:55 PM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
Epoxy the new transom core (marine grade plywood) to the inner and outer skins of the old transom. They need to be clean and possibly roughed up a bit with a grinder to take a good bond.
Poplar was used as planking in small boats for years, but the good stuff (yellow poplar) has been all but cut down. The remaining cousins of this species are not nearly as good, having wider growth rings, less rot resistance and less strength. You can get poplar faced plywood panels, but this is usually cabinet grade stuff and not suitable for life on a boat.
Replacing the plywood core inside a transom has been discussed many times here. Try a search for transom replacement.
Old 06-20-2006, 05:48 PM
SamSam SamSam is offline
Rep: 455 Posts: 1,606
We always put 2 layers of 1 1/2 oz mat against the old fiberglass transom and then clamped a sandwich of 2- 3/4" plywoods with a layer of 1 1/2 oz mat
between them to the transom, all of that at one time and fairly resin rich.(polyester) If there is too much curve in the transom you can use more layers of thinner plywood. If you don't have enough BIG clamps (you don't) you can drill holes through the transom and plywood and use threaded rod or bolts and 2x4's to clamp it together and then plug the holes afterwards. Put plastic sheeting under the 2x's to keep them from sticking to things you don't want them stuck to. Also wax the outside of the transom first so oozes and runs will come off easily. I wouldn't use boards in the transom, plywood is more dimensionally stable and probably stronger. Sam
Old 06-20-2006, 06:32 PM
Rep: 95 Posts: 462
i often use drywall screws to pull
the plywood to the old fiberglass lots of resin rich mat to let it bind with out voids
Old 06-21-2006, 10:57 AM
stevel stevel is offline
Lost at sea
Rep: 10 Posts: 118
Same here
I cut some 3" squares of ply to use as washers on the drywall screws that I used to pull the plywood into the curve of the transom. The tiny holes that you drill through the glass for the screws are easy to patch.
Old 06-21-2006, 04:36 PM
Rep: 10 Posts: 10
thanks guys,all good suggestions.i guess i'm lucky that the inside of the boat is open so i can get at it! i just finished ripping out the old transom and ground all the old plywood off. half was rotted the other half good.(DAMN IT!)well guess i'm on my way.maybe i'll get to use my boat this year!?--------------(1988 Larson 170 citation bowrider) 2.5 mercruiser....
Old 06-21-2006, 06:13 PM
Rep: 10 Posts: 10
you guys got any pictures? would love to see them!
Old 06-21-2006, 11:39 PM
Rep: 10 Posts: 10
mat
would that be chopped strand mat?
Old 06-22-2006, 11:19 AM
Lost at sea
Rep: 10 Posts: 118
Chopped stran is what I used
Not to step on Sam's toes, but yes, chopped strand is what I used and what I've seen used. Don't worry about normal resin to glass ratios like you would for strength in a layup. Just get the mat saturated and clamp it well to avoid any voids. Your enemies here are gaps and voids.
Old 07-08-2006, 02:18 PM
chandler chandler is offline
Rep: 16 Posts: 378
Don't use poplar, it's about as dimensionally unstable a wood as there is
Old 07-08-2006, 07:10 PM
Rep: 10 Posts: 10
OK! thanks!
transom support James Francis Boat Design 0 05-29-2006 12:09 AM
Doing a walk-thru transom Ctskip Sailboats 1 05-08-2006 07:50 AM
L on 25" transom RTek Propulsion 0 01-24-2006 12:19 PM
transom bammy the bass Fiberglass and Composite Boat Building 1 09-27-2004 06:03 PM
help with transom bracket anthony c Boat Design 0 09-26-2004 04:05 PM
