Old 10-13-2010, 12:43 PM
freeski27 freeski27 is offline
Naval Arch. - Student
Tow Tank Model Build?
I am a Naval Architecture student here in NYC, USA and I plan on building a tow tank model of a small sailboat design that I have done. I tried to find some decent info or literature on model builds, but didn't come across much.
The scale model will be just over 3 feet long. How do you recommend going about the build? Carve foam? Cut sections from wood and try to glass? etc. Any advice would be very helpful.
-Noble
Old 10-13-2010, 01:03 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Glass or epoxy over carved foam.
-Tom
Old 10-13-2010, 04:21 PM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
Saw or slice up thin 'flexy ply' into 'strips' as appropriate for the curvature of the model.
Strip plank over frames cut from regular ply. Use epoxy thickened with West Microlight.
Skin with glass tissue and epoxy.
Old 10-13-2010, 05:30 PM
wardd wardd is offline
Rep: 443 Posts: 925
here's another way cut out the station outlines out of anything mount them to a board and fill the voids anything, crumpled paper.
layer modeling clay over it and fair with a spline
build a box around the base and coat with a good release agent such as simonize..
pour plaster in to make a female mold.
after its cleaned up a model can be made of paper mache and sealed
liberty ships were beautiful
Old 10-13-2010, 07:39 PM
Rep: 501 Posts: 1,760
OK, so I have tank and models then what? What else do I have build to get a working idea of which hull is better. Sorry for my ignorance, I am building dingy and would like to try a few models.
Old 10-13-2010, 07:42 PM
Rep: 443 Posts: 925
do you have a swimming pool?
Old 10-13-2010, 09:47 PM
No, I was going to build RC boats and try in pond....
Or could borrow pool..
Old 10-14-2010, 08:12 AM
Rep: 443 Posts: 925
use the filter out flow and a mail scale for drag readings
a simple way would be a line over a pulley to a weight on the scale, read how much the weight weighs as the model pulls on it
a mod on on the mold, if you cut out half hull shapes you can make a mold that splits down the keel, turn the shapes around for the other half
the nice thing about this method is common cheap materials
Old 10-14-2010, 11:08 AM
apex1
These are made of cnc milled poplar wood.
http://www.hsva.de/
Old 10-14-2010, 11:54 AM
Rep: 572 Posts: 635
The test tank world is highly competitive, in the scope of the facilities offered, the quality of the analysis and the cost of running a program.
A major part of this, is the quality and cost of the model. There are loads of different techniques for their construction, but not all are even applicable to high tech yachts models. The CNC poplar models above are not going to mimic the moments of an AC90.
In my experience the best quality models and the most cost effective are made in wood strip by a skilled model maker. Luckily a view shared by most of the leading designers, AC / Volvo campaigns and even ferry companies.
Old 10-14-2010, 12:02 PM
apex1
I doubt there are better model makers in the world than the guys at HSVA.
But of course, the smaller the vessel a model has to mimic, the more effort has to be made.
The most cost effective are still CNC milled, not handmade.
two of them:
Regards
Richard
Old 10-14-2010, 12:04 PM
Rep: 1493 Posts: 7,447
To make a significant comparison between a model and what you plan to build, the displacement and moment of inertia have to be proportional. Whatever method you use, should give you the same numbers as the calculations for the full size boat.
Old 10-14-2010, 12:06 PM
Rep: 443 Posts: 925
but couldn't you compare 2 or more models against each other for the better performance and extrapolate that to the full size, saying this one will perform better than that one?
Old 10-14-2010, 12:47 PM
Rep: 572 Posts: 635
I'm sure the guys at HSVA are perfectly good ship modellers, but they're not a big player in the yacht test tank world.
CNC has been touted as 'the answer' for years now, but unfortunately has yet to make an impact except where there isn't the skill base for using an alternative.
As I say, the tank testing world is highly competitive and I know exactly how the cost and accuracy of various methods compare. The various methods are constantly evaluated and so far, with yachts up to 200ft the model maker still rules on price and accuracy. If it didn't, we'd use the alternative.
Carbon Tow - Where? Inquisitor Materials 0 07-09-2010 11:14 AM
Smallest model scale for representative tank tests ? Boo2 Sailboats 13 03-22-2010 08:55 PM
Design project - model tow test Brands01 Powerboats 6 01-10-2007 03:48 PM
Stevens High-Speed Tow Tank Re-Commissioning and Technical Symposium CDBarry Press Releases 2 10-13-2006 12:35 AM
want to build a small model of a boat ronen Boatbuilding 2 12-29-2003 05:35 PM
