| Tight cutlass bearing I am using 10inch cutlass bearings for my rudder shafts. This works very well and cured a vibration rattle that I had previously. However the bearings are still a little bit tight and have got tighter. It still steers Ok but but I thought I would drop the rudders out at the next haul out and try to grind out the bearing a tiny amount without removing the bearing from its tube. I was thinking of a grinding disc ground down to 50mm and put onto a threaded bar with nuts holding the grinding disc, with a bit of washing up liqiud as a lubricant I thought a couple of passes with the electric drill would just shave a bit off. Or a 50mm piece of wood turned down to 49mm and coated with epoxy and sand. Any better ideas. |
| A simple wooden stick of say 1,5 - 2cm diam. with a slit sawn in, then a piece of sandpaper inserted into that slit. Put the stick in a el. drill and go sanding. Although only one side of the sandpaper will work, it does the trick, you will remove only a bit. Regards Richard |
| Max weight of shaft/prop on cutlass bearing | kaakre | Inboards | 2 | 01-19-2010 07:18 AM |
| cutlass bearing first or last? | pasty63 | Inboards | 1 | 02-13-2009 04:15 PM |
| how tight is tight in mainsail | RonR | Sailboats | 21 | 08-20-2008 06:41 PM |
| Long stern tube with dual cutlass bearings? | RyanN | Inboards | 4 | 10-18-2007 07:16 PM |
| 'Tight' V Boat | Powerboats | 2 | 02-02-2003 09:55 AM | |
