Old 08-31-2008, 01:34 PM
SeaJay SeaJay is offline
Rep: 10 Posts: 79
Suggestions?-Engine Sump/Bilge
I’m looking for tips, ideas, suggestions, etc., on the design of the bilge area immediately under the engine. This is new construction so I have a clean slate to work with (the engine is a Beta 75 hp). Questions in my mind have to do with clearance under the oil pan, bilge drainage, and oil containment. This may not be a critical detail, but ideally, how should this area be set up? Any input is appreciated.
Regards,
SeaJay
Old 09-04-2008, 04:26 PM
mongo75's Avatar
mongo75 mongo75 is offline
Rep: 95 Posts: 258
We need more specifics- are you just asking how the area should be built?
Danny
Old 09-05-2008, 12:03 AM
Rep: 10 Posts: 79
Danny,
I'm interested what needs to be considered in this area...for instance, should drainage from aft of the engine just run directly under the engine, or should I laminate a couple of pvc drainage to the keel and then form an oil containment sump around the engine. I would like to get the engine down as low as possible, but am wondering if I may be overlooking something. I'm not thinking I'd want to drop the oil pan, but you never know if the gasket might leak. The Beta engine has a built in oil change pump so I wouldn't have to get a the drain plug on a regular basis. As I said, it is not a critical issue, but I thought I'd check to see if anyone had 2 cents to say on the subject.
Regards,
SeaJay
Old 09-05-2008, 10:36 AM
north stream north stream is offline
Rep: 10 Posts: 3
Seajay,
do you have enough room under the engine that you may access for maintenance or cleaning purposes,if possible, you may create your oil collecting tank install a sump pump and connect to your discharge system for waste oil.
cheers!
Old 09-05-2008, 02:04 PM
Rep: 10 Posts: 79
North Stream,
I have considered what you have suggested. If I use the Beta engine, this should not be necessary on a regular basis as the oil change system is built into the engine itself and is accessable from the top. A containment sump could be handy but would limit access to the area below the engine.
One thing I should have mentioned is that the boat has a "canoe" shaped hull and is very flat in this area (both forward and aft as well as athwartship),making for minimal clearance underneath.
Suggestions Anyone? asianbandit Fiberglass and Composite Boat Building 1 10-22-2006 02:03 AM
bilge keels roxanne parola Sailboats 21 03-10-2006 11:35 PM
Looking for Suggestions Sands Boat Design 15 01-23-2006 09:25 AM
Bilge pumps redcoopers Sailboats 4 09-19-2004 06:36 AM
Suggestions are welcome!! pbrito Sailboats 7 09-20-2003 03:20 AM
