| Substitute for bleeder / breather Living in the sticks has several advantages. None of which are related to being close to boatbuilding supplies and material. Looking through the inventory this morning I noticed that I am out of bleeder/breather and was hoping to do a few layup today. Anyone ever substituted anything successfully in this arena..??? |
| I found some materials at the local sewing/fabric store that work relatively well. The nylon inner liner material used in coats & such works well as a peel ply and their polyester fiber fill (insulation) batts works well as a bleeder material. Neither are cheap but work in a pinch when you run out of the real stuff. I suggest getting some small samples and trying them with your resins before you risk a part. The nylon inner liner is harder to pull off than a properly treated peelply.
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| bagging materials I have some in my ebay store composite-aero |
| Burlap OK... Wound up using burlap that worked great! Absorbed all resin. Worked well.. Obviously the peel ply kept the burlal from getting laminated in.. |
| Substitute for Oregon | Wood Boat | Wooden Boat Building and Restoration | 3 | 03-26-2007 09:08 PM |
| Can I substitute vinylester for epoxy? | Stephen Ditmore | Materials | 7 | 12-19-2006 02:23 AM |
| Can I substitute Honduran Mahogany? | Swimpy | Wooden Boat Building and Restoration | 6 | 08-04-2006 08:11 PM |
| Acoustic/Sound tile substitute? | daveschile | Materials | 4 | 03-12-2005 11:55 PM |
