| is it strong enough Hi guys It is my intent to build the glen l 15' 9" console skiff with raised bulwarks. I intend on building it to their specs, I'm also a diver and do alot of diving my question is, would I be able to continously pull myself in over the side of the boat without damaging (structurally) the boat. It is a stitch and glue boat with taped junctions and a layer of 7.5oz cloth on the interior as well as the exterior using epoxy resin. do you guys think this boat is just for pleasure riding or do you think it will suit as a dive boat as well as it will be the perfect size for diving in some areas i like to dive.Once again guys thanks in advance and any input will be greatly appreciated check out the boat CONSOLE SKIFF by Matt Marzullo, on the GLEN-L site under customer photos and tell me what your opinions are THANKS web site is glen-l.com |
| Nice looking boat - and Matt built a real "gold-plater". Sounds like you want a workboat - probably workboat finish, definitely workboat strength. And the scantlings specified on the Glen-L site look a bit light - mostly 3/8 ply - for hard North Atlantic use. Do you beat on your boat? Shore landings? Drop your gear on the deck? Pound through chop? Cold weather use? How do you "pull yourself over the side" now? I would assume you will need to modify it with a permanent rugged ladder, hand holds, and maybe a cut-down section of the gunwale. Matt's boat has massive rails, should be plenty strong - are those to plan, or his modification? I have a Bolger Diablo, similar size different bottom, and find the flat-bottom double chine shape does well for climbing in - the boat heels right over to put the gunwale near the water, but no further. Sal's Dad |
| Creating a strong enough transom | TP-Mike | Boat Design | 1 | 02-11-2006 01:02 PM |
| Strong enough??? | DanBlack | Boat Design | 6 | 12-26-2005 07:02 PM |
| Heavy strong designer | JimCooper | Boat Design | 5 | 06-04-2005 01:11 AM |
