| Much of the muchness mate. Bead and cove planks work well with square section planks or hulls having long runs (multihulls for example) but the problem lies in the fact that since most strip plank composite cores are anything from 6mm upwards, having a square section here is ridiculous. For example a 9mm square section means a lot of planking and glueing. Thats why most plank with rectangular planks. Another problem using bead and cove rectangular planks means you still have to fit the planks (if you don't want edge set) which means that you have to either cut off the bead or the cove. Cut off the bead and you've cut a lot of filling to do in the cove. Cut the cove and you'll have trouble working the glue around the bead. I've mucked around with bead and cove and personally I found the whole idea a waste of time and money. It was ok planking the topsides, but planking the turn of the bilge and the bottom plate was damn frustrating. Overall bead and cove , like all things, has it's place. What you do is up to you !! Quote:
I did some testing today on some gaboon plywood which was sent to me to test (mechanical properties and density). They advertised the plywood had a density off 430 kg.m^3, yet on testing it was between 580 - 600 kgm^3. That is a huge difference and overall, it will add a lot to the hull weight. This is what you need to be watching out for.. more than anything. I actually wrote an article on this a while back, but that's another story. Here's the link: http://www.bowdidgemarinedesigns.com...s_Article.html Hope this helps Anyway, have a good one and havagreatweekend Mark |
| Thanks Mark, Nice to see someone post a video that shows how simple strip planking can be, there are many potential boatbuilders out there that have never actually seen it done before, your method is of course one of a million different versions, but at least it is out there, ta mate. John
| Your welcome have a good one |
| G'day all, One thing that I didn't mention here or on the video, but is mentioned in the plans is regarding the glue mixture. You don't use straight glue powder, but you mix 50/50 cabosil and microballoons. This way the cotton flock creates the binder within the mixture and using microballons reduces the overall weight of the mix. Hope this helps |
| Thanks Mark. So at some point in plank thickness you would suggest changing to a "wet" gluing method? And I guess that thickness would depend on the amount of arthwartship curvature... Looking fwd to the next installment of the videos... ![]() |
| G'day Mat-C, Wet gluing..hmmm. It would all depend on the boat but more importantly the type of build. Lets say I'm building a traditional strip plank boat where the strength of the boat or build is dependant upon the strength of the plank and is then overlaid with a thin layer of glass (ie 200gm or 6oz cloth) on the outside for abrasion. Here I would plank as normal (wet glue) because this type of build typically requires a thicker plank when compared to strip plank composite. I would then plank as per the "wet glue" method, however I would use planks that are square in section to make it easier to plank. As our designs are engineered as composite strip plank, not as a traditional strip plank design, in this regard, the planks can be thinner and the overall strength of the build is not dependant upon the plank mechanical properties (except for core shear strength) but on the inner and outer laminate mechancial properties. This means I can plank the boat using the "dry method" as the overall build is then laminated or sandwiched between the glass. Does this help? Last edited by Oceansky : 08-19-2011 at 08:59 PM. |
| Hi Mark Thanks for the long phone call this morning - found it very informative. I had considered this technique some time ago, Wide Gap Strip Plank - what problems could this building method cause? so I was wrapt that it actually will work, and even more important, that there was someone who could do the engineering calcs on it, I think the method is going to save a lot of people a lot of work. |
| strip planking v ply | wardd | Wooden Boat Building and Restoration | 25 | 02-08-2011 08:55 PM |
| strip planking vs aging | urisvan | Wooden Boat Building and Restoration | 16 | 12-06-2009 04:54 PM |
| Speed Strip tongue-and-groove strip planking | Jeff | Materials | 38 | 08-04-2009 11:12 PM |
| Strip planking vs wide planking | jfblouin | Wooden Boat Building and Restoration | 26 | 08-11-2005 09:00 PM |
| Books - strip planking | mojounwin | Fiberglass and Composite Boat Building | 1 | 01-06-2005 03:04 PM |
