Old 07-22-2010, 09:20 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Stringer question
Do soft chine sailboat hulls need stringers?
I have been looking at many builds and restorations and I haven't been able to find any good examples.
Does it depend on the laminate thickness if they are installed or not?
Thanks
Old 07-23-2010, 11:36 AM
Rep: 1493 Posts: 7,447
Are you talking of fiberglass? Stringers may or not be used. Often, the interior cabinetry takes the place of stringers.
Old 07-23-2010, 12:43 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Yes fiberglass, and single skin.
I have seen builds out of plywood that is fiberglassed over that incorporate stringers but not any single skin with fiberglass or other stringers.
The reason I am interested is I worked out the scantlings for my boat, and 5 stringers per side and 5 bulkheads are the requirements, however the glass layup is over twice as thick as the scantling calculation. So I was thinking the glass or hull thickness was the reason the soft chine don't have stringers like other builds?
But the cabinetry would make sense to
Old 07-24-2010, 02:49 PM
The scantling calculations are for a particular building method. Each method ends up with different scantling for each part of the structure.
Old 07-25-2010, 09:16 AM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Thanks Gonzo.
I used Gerr methods for Fiberglass solid-glass hull shell.
Is it realistic then to take these rules and apply them to an existing boat that was designed by engineering methods or others and not scantlings or this specific set of rules?
The purpose would be for an Internal structure rebuild, or additions.
Old 07-25-2010, 10:09 AM
You can study an existing structure, mainly to see if it was build strongly enough. However, you need to use the same method. Also, the boat has obviously lasted quite a while. I would say the scantlings are fine. You may ruin a boat by changing major structural parts.
Old 07-26-2010, 04:24 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Yes that sounds good to me, would an accurate description of these hulls be monocoque with the loads being spread around the skin and deck structure?
There must be something that was done right for a hull to last 36 years without defect.
Newb with stringer question Shinchan Fiberglass and Composite Boat Building 4 03-29-2009 05:50 AM
Another stringer replacement question mongo75 Fiberglass and Composite Boat Building 4 02-21-2008 10:51 AM
Stringer Lumber question? holly Multihulls 12 08-08-2007 11:20 PM
Second Stringer question pairomedicsfish Fiberglass and Composite Boat Building 6 09-22-2006 12:47 PM
Stringer repair question sleeper Fiberglass and Composite Boat Building 15 01-04-2005 04:43 PM
