| stitch & glue plans conversion to aluminum Can stitch & glue plywood plans be converted to welded aluminun plans ? I like the hull and design of the Tolman skiff but my needs require an aluminum hull . What boat building books do you guys recomend ? Thanks ! |
| BOAT STRENGTH by Gerr and BOATBUILDING WITH ALUMINUM by Pollard would be a good start. Doug Carlson |
| any progress I got some values from gerrs book and some general bending strenght for plywood vs aluminum. Any comparisons that you got for your tolman? |
I asked the same question of Renn Tolman and he said: Jim Are you kidding? There's never been a leak in a Tolman Skiff--unless you count the one that hit the log at 25 knots--and I've built 103. That's more than can be said of aluminum, which frequently cracks at the welds or pops rivets. But if you've got to have an aluminum skiff, have at it. However, you'll have a tough time building one from my plans because you need the flat-panel shape for all the hull panels, and I only give you the shape of some of them. Renn I'm still curious about building in aluminum, but I'm not sure about how much support would be required, and where. Any insight would be appreciated. Jim |
| Are Your Glue Joints Repairable? | Bob Smalser | Wooden Boat Building and Restoration | 16 | 04-18-2007 06:23 PM |
| Are Your Glue Joints Repairable? | Bob Smalser | Boatbuilding | 10 | 03-02-2006 05:20 AM |
| convert wood plans to aluminum construction | lynnburcher | Metal Boat Building | 4 | 07-12-2004 10:49 AM |
| STITCH & GLUE , SOLID FIBERGLASS , or ALUMINUM ? | jbelow | Materials | 3 | 05-01-2004 12:45 AM |
| stitch and glue | Boatbuilding | 2 | 06-27-2002 08:33 PM | |
