Old 12-06-2009, 06:21 AM
stonedpirate stonedpirate is offline
Rep: 21 Posts: 315
Stitch and Glue?
Hello,
I have heard some designers speak of hull skins made with multiple layers of ply.
My question is, how do you do a multi layered ply with stitch and glue?
Is each layer epoxied onto the one beneath it?
Or do you not need epoxy between each layer, just on the edges?
THanks
Old 12-06-2009, 09:38 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,355
Any place two pieces of wood contact, they should be glued and sealed. Pages in a book do well glued down the edge, but layers on a boat, not so well.
Hoyt
Old 12-06-2009, 10:13 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
The purpose of stitch and glue is to build a hard-chined boat from plywood.
The shape of the boat is therefore made up from conical (flat panel) sections.
In a sense, what you call multi-layered is shop-made plywood, but the reason it's done is to make a hull with rounded sections.
This method is generally called cold molded. Since the whole hull is of one piece, no stitching is required.
The exception that comes to mind, where many-layered panels are stitched together, is called Constant Camber, where all hull sections are made from a simple convex panel that's built on a form.
The simple convexity is built into the panel, and the design cleverly uses that single panel shape for all of its parts. The panels look a lot like the skin of an orange slice.
The advantage is a comprimise, working best with a design specifically drawn for use with the method, but useless for building any non-constant camber design..
Old 12-06-2009, 07:03 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 681
Stitch and glue the panels .
Fillet.
Laminate one ( or ) more layers on top as desired / required.
You can use vac. , staples , screws , etc.
These can be removed after glue is set.
Yes.
Other glues can be used.
No ! No voids. ! If you glue edges only , you will have one great big void....
See the problems of voids in plywood....
How big a reproduction are you thinking and do you have crew and money dripping off your butt?( PAR2009)
Old 12-06-2009, 07:09 PM
Rep: 21 Posts: 315
Great, thanks a lot guys
Old 12-06-2009, 07:33 PM
boat fan's Avatar
Rep: 357 Posts: 681
Be aware that...
Be aware that if you add hull skin thickness , the boat gets heavier.
If you add extra layers to your hull , beyond the original design specs ,
you will lose that extra weight in payload capacity.
If you add to the hull weight , and load the "designed for" max. payload
your boat will float deeper than designed.
Generally bad........
Old 12-06-2009, 08:04 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
Multiple layers of ply.
Multiple layers could be called for in areas of high curvature where a single thicker layer could not be bent to the desired camber. Also some builders will laminate additional layers to get the total hull thickness.
Hey, Alan. How's it going? Still not in Maine, but we are sure trying!
LP
God bless the open minded people of the world. LP
Old 12-06-2009, 09:20 PM
alan white's Avatar
Hey! Glad you're still working towards moving. I've got a couple more boats to go through, lots of work when I can find time. Stop by when you're in town again.
Old 12-06-2009, 09:46 PM
Rep: 3125 Posts: 9,395
You can also use multiple layers of plywood to conform to compound curves, much like cold molding veneers. Another option is to slit the plywood so it'll "lay down" on a compound curve, covering the slit areas with the next layer. This is common on "Carolina flare" bows.
stitch n glue Pelican? Phildave Boat Design 0 02-04-2009 06:32 AM
stitch and glue? kayakn Wooden Boat Building and Restoration 4 07-21-2008 11:08 PM
Stitch-n-glue or Strip? Neverbehind Wooden Boat Building and Restoration 13 04-21-2006 09:06 AM
26' stitch and glue regal Boat Design 5 07-09-2004 12:10 PM
stitch and glue Boatbuilding 2 06-27-2002 08:33 PM
