| Steering chase size... Remodeling my fiberglass tiller style boat to a CC style... Curious to know what kind of chase, or conduit would I need to install from the center of the boat to the transom... Basically, will the TeleFlex steering system I intend on buying fit in a 1" pvc conduit... or do I need to go bigger... The boat is 16feet... How should the conduit be ran... Straight back, or should it be ran to the aft, and then towards the stern... I would think that'd be more bends, and less accuracy... I dunno. Thanks for your help guys... Bear with me, I'm a rookie... ![]() |
| Most boats of this type run an approx 3" chase. There will be MUCH more than just a steering cable, and with the nut that cable alone will need more than 1". The engine cable that carries the insturments and ignition wires, the control cables (2) for throttle and shift, battery cables if the battery will be in the console, a cable for the transom mount transducer for the depth finder, maybe a stern light wire. Sometimes 3" isn't enough. It should be run towards a corner because the cable needs to attach to the motor from the side. Where you are there should be hundreds of boats that you can take a look at. Steve |
| Thanks Steve. I wonder if I shouldn't just run two chases then... One strictly for the steering, and the other for electronics, and whatnot... Thanks. |
| Collect up the stuff thats going to go thru and take a look. No reason you can't run multiple chases, no reason to dedicate one for the steering cable either. It's amazing how quickly any chase on a boat gets choked. One suggestion, when your pulling stuff through leave a line to use as a snake so in the future if you need to add something your life will be much easier. |
| meshing hydraulic steering with cable steering - how do you do it? | Guest1578132542 | Boat Design | 4 | 07-14-2010 06:27 AM |
| wind steering servo blade size | idlerboat | OnBoard Electronics & Controls | 0 | 12-10-2008 02:40 AM |
| Olympic Chase Boats | JCNalen | Boat Design | 6 | 10-03-2008 04:30 PM |
| A matter of scale: what size steering wheel? | BruceS | Boat Design | 2 | 10-16-2007 10:43 PM |
| Under floor cable chase question | Greavous | Boatbuilding | 6 | 02-15-2004 03:54 PM |
