Old 01-05-2003, 03:32 AM
hendrikus hendrikus is offline
Rep: 10 Posts: 7
Stainless steel / Aluminum
We are building at this moment yachts between 25 and 100 meter using ordinary steel and steel constructions. We planned to build one yacht with stainless steel.
This because of the following reasons:
Stainless steel we can use 6 mm comparing to 8-10 mm normal steel
No painting
Less maintenance
No big change in the current logistics and way of working
Stainless is a local product of Indonesia and sheep in comparing to Aluminum.
Who has an opinion, what are the + and – in your opinion.
Hendrikus
Hendrikus Postma
MR-Shipyard
Kalimantan - Indonesia
Old 01-17-2003, 04:49 PM
Rep: 1397 Posts: 7,215
The biggest problem with stainless steel is crevice corrosion, specially at the welds. You should check with a metalurgist. In the USA the best I've worked with is Q Metalurgic in Florida.
Old 03-18-2004, 05:19 AM
Turntide Turntide is offline
stainless steel boat
undefined
No painting
Less maintenance
Hendrikus
I have worked with stainless a lot and believe that some people with advanced sheetmetal/ welding/ panel beating / polishing skills could build a very goog boat from sheet thicknesses up to 4mm. Stainless has servere shrinkage characteristics in the weld zone not to mention oxidadation. Basically the more you weld your boat the smaller it gets. Once the hull is enclosed and is damaged, the repairers must have access to the inside of the repair in order to shield the heat zone with argon and then applie a dolly for stress relief treatment. So I believe its possible to build in Stainless but would cost much more than steel.
Note A good stainless job is taken for granted, a bad one is an eye sore.
Old 02-09-2005, 03:44 PM
webbwash webbwash is offline
Rep: 10 Posts: 35
Better to keep with ordinary steel, it is something you can get at any ship/boat yard and even metal fabricators ashore usually have a grade which is compatible with your original material. Besides it doesn't take too much to weld ordinary steel, just practice and the right welder.
Stainless and skilled stainless steel welders are not as readily obtained, plus the added cost of inert gas shielding and the not so little problem of crevice corrosion common in poorly made stainless joints.
As for worrying about maintenance -- you still have barnacles and bottom coat to worry about, and the deck and ........... you get the picture, you will always want to do something in the way of coating. Save the stainless for the galley counter and maybe the fresh water tank -
Old 03-01-2005, 11:22 AM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
I just read an article on use of stainless steel on submerged areas. It sounds like a BAD IDEA. Salt water and moving water interferes with the passivisity of the stainless, making corrosion unpredictable and portentially aggressive. Obviously for a hull, we are talking about a huge area, but active stainless on a scratch on the hull bottom will lose electrons to the passive stainless on the relatively larger hull surface and rapidly start to destroy the hull where the scratch was. I think they said that stainless loses it's passivisity over 3 months
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 06-30-2006, 07:40 PM
Lyle Creffield Lyle Creffield is offline
Rep: 10 Posts: 35
Stainless steel vessel?
Hi Mr Builder
I would be very interested to see what life a large S/S vessel will have
S/S work hardens, that is to say when the material is put under stress loads as in a vessels hull it continues to gain hardness to a point where it will no longer flex and there fore must fail eg S/S rigging
The same properties that prevent corrosion also reduce ductility
Sir i am sure you have more expertise than i and would very much appreciate understanding why S/S construction material will not eventually fail
cheers
lyle
Aluminum vs. Galvanized Steel WAHiggins Materials 6 06-02-2005 01:32 AM
Steel and Aluminum Boatbuilder, Pac.N.W. SolomonGrundy Metal Boat Building 1 03-21-2005 09:33 PM
Overuse of cathodic protection on aluminum or steel hulls Thunderhead19 Boat Design 6 02-28-2005 07:20 AM
shroud attachment...steel or aluminum zoomee Sailboats 1 10-22-2004 10:45 AM
Looking for job with steel and aluminum Boat builder Services & Employment 0 03-26-2002 10:33 AM
