| Soft wood epoxy soak This is a bit of a random one, but I want to reinforce soft wood with epoxy to make it harder, the wood I am using is poplar and is 1.5mm thick. The problem I have is that the epoxy just sits on the surface of the wood and doesn't penetate and give the wood any aditional structure. What i want the epoxy to do is to soak in and really make the wood hard, how can I do this? I have tried thinning the epoxy with denatured alcohol but this still isn't very effective. I wonder if heating the epoxy or wood would help create better penertration. Can anyone offer any advice on my sticky situation! ![]() |
| Nedgrater, Are you trying to give the wood a harder surface for dent resistance (ie, a table top) or are you trying to make it stronger? A hard surface might be achieved with some thin (say 4 oz) fibreglass cloth set in epoxy; this is light enough that it should still look like wood. Straight epoxy should soak into the wood enough to seal it and keep it from getting wet, but won't add much if any structural value. Cutting your epoxy with solvents is unlikely to work too well; it may thin the resin, but it'll also weaken it, defeating the purpose. Heat can sometimes lower the viscosity of freshly mixed epoxy, but also greatly accelerates the curing process.
| what about CPES clear penetrating epoxy sealant |
| I think you need to Vacuum Bag the wood to force the epoxy into it. Vacuum to force liquid into porus wood sounds a little counter-intuitive, but that is how they tread wood of knife or gun handles. Not sure of the exact process or if they are using 'normal' epoxy, or if this method works for boat sized lumber. I bought a thin(like water almost) clear epoxy in a 8 oz bottle that is supposed to be for making dry-rotted would all epoxied and sound. I never tried it on anything. I have a hard time imagining regular epoxy getting more than 1/8" in most wood before hardening. |
| Hard to do The idea of getting epoxy to suck itself into the edge of grain is not something I have ever seen. Epoxy when warm can certainly get thin and then suck up end grain. This is certainly an effect you need to consider when gluing scarf joints that show exposed end grain. Think of wood as a collection of straws. You can easily get epoxy up the ends but getting it in between the straws is basically impossible to any depth. As for vacuum bagging, I don't wish to seem rude, but I can't see how this could help. Bagging is usually used to remove epoxy from a laminate. I have never heard of it being used to push epoxy into wood. I do a fair bit of bagging (just did one yesterday) and it makes great laminates. If the idea is to harden the timber use a very light layer of fine cloth. Adding epoxy on its own will do very little to increase the mechanical properties of the timber without glass. cheers Phil |
| Use heat not thinners As Mashmat rightly said don't thin epoxy. Use heat to thin it. Make small mixes and warm it up to make it runny but don't ever alter the ratios and stay away from thinners. One reason - there are many different types of epoxy and it takes a chemist to work out what type uses what reducer and two - the thinners like Toluene are cancer causing chemicals. Stay away from them. Throw away brushes and clothes or use white vinegar |
| As has been mentioned, heat is the best way to get better penetration, not thinning the epoxy, which just weakens it. I suspect if you are having difficulty with penetration, there's something sealing the surface, preventing it. It would be helpful if you offered additional information about what you're trying to do. Plus the state of the wood. We know about the rot, which we can assume is a pocket or an affected area. Is it painted, varnished, treated with wood preserver, etc. and other such bits about it's condition. |
| Wow thanks for all the feed back! I am trying to gain dent resistance rather than over all strength of the wood, but am reluctant to use a cloth as I want it to look like plain wood. It sounds like the general idea is that I should use heat rather than thinners. I had an idea about how i maybe could do this- Mix some epoxy at a good working temperature, then when the epoxy is on the surface of the wood, heat the wood so that the epoxy soaks in due to the lowered viscosity. While the epoxy is still uncured repeate the process so that as much epoxy is absorbed into the wood as possible. Thats the plan anyway, I think i'm gona give it a go and see how I get on. The wood I'm using is new wood. I too cant see the vacuum method working, I thought the reverse may work though- a pressure chambre, but this seams like alot of effort and the results maybe negligable. I'll do some tests today and post my results tommorow. Thanks ![]() |
| Rather then making all these grandiose guesses at treating this wood with epoxy, how about absorbing a little information, before you make more mistakes. Log onto www.westsystem.com and www.systemthree.com and have a look at their user's guides. It discusses their products, applications, techniques, etc. With this information you'll at least have a level playing field and not be wasting material and time trying different things. I mention this because, if you heat the wood while the epoxy is on it, the wood "out gas" and you'll have bubbles all over the surface. If you use fabric (cloth) weights 4 ounces or less, you will not see the weave once the epoxy wets out the fabric. The vacuum methods hinted at previously, will work quite well for you application as we understand it, but does require some specialized equipment and supplies that you may not have. How about some specifics, what species is the wood? Have you sanded it and with what grit? Is the wood treated in any way? What are the average temperatures you're working in? What brand of epoxy and the hardener type (speed)? |
| Epoxy will only soak approx 80 microns into side grain and only 2-3 mm into end grain in light soft wood, less in dense wood. This is why it is possible to infuse end grain balsa at 100% vacuum without filling the core with resin. You will get better results with low viscosity resin like infusion grade as this resin has higher concentration of reactive diluent, not solvent. Also heat the timber prior to applying epoxy so that it draws the epoxy in as it is cooling and not the other way around as already mentioned. I go along with the recommendations to use a light weight glass like 200gm2 plain weave, do a test piece and you will be surprised how translucent the glass is. If you do not want to use glass then you will need to build up the neat epoxy to a reasonable thickness with a number of layers. Floor surfacing epoxy should also be best choice as it is harder than marine epoxy. |
| poplar...not the best of boat woods. |
| I saw a 'demo' on TV of vacuuming in epoxy to wood. It wasn't how they did it commercially, just for demonstration purposes. They had a block of wood about 6" covered with epoxy in a vacuum chamber with a window. They turned on the vacuum and at a certain point bubbles began to emerge from the wood, and at a certain point they dwindled. Not much movement from the surface of the epoxy. Apparently the air and ANY WATER was being removed and replaced with epoxy. The water was being removed as it boiled in the low pressure. I guess epoxy doesn't boil in low pressures like water. I'm not sure if this would work with a bag, or how it is done commercially. Here is "resin infused wood handles" knife: This stuff all looks laminated, though. http://www.rutply.com/products/dymondwood-gallery.html |
| I did a test peice today in the way I described in my last post and am waiting for the epoxy to cure. The vaccum is an interesting idea and now sqidly-didly explained how it may work, it now makes more sense to me, (sorry for dismissing it earlier). As far as I can picture it if epoxy is sitting on the surface of the wood and then the vaccum removes air from the wood the epoxy should be forced into the vaccum spaces in the wood. I have actually got vacuum equipment, so I am quite keen to give this a try, but would be grateful for any tips or tecniques before I do. The epoxy I'm using is Resin Research epoxy. Thanks for all your help so far guys... |
| If a clear high gloss finish is essential, make sure you use the correct Hardener. West Systems 207 hardener is the only one they recomend for really high quality finishes. It costs more than the resin, so it better be good. |
| I did a test peice, by heating the wood, applying warmed epoxy and the heated it further still, I did this a second time then let it cool and cure. When it was cured I sliced the timber in half to see how far it had penetrated, and it had gone down about 1mm. The poplar timber I am using is only 2mm thick. I was fairly pleased with the results, and it made the surface of the wood fairly dent resistant. I haven't yet tryed the vaccum method, but plan too in the next few days to see if I can get a better result again. I belive that as a few of you have described by heating the wood you are releaseing water and air from the wood, if the warmed epoxy if then applyed and the wood allowed to cool, this I imagine will have a similar effect to a vaccum as it would pull the resin into the voids created by the cooling wood. If the results from the vaccum method are fantastic, I will use that but if the results are not very different from the heating method I just described I think I will stick to that, as its a pretty user friendly and quick process. |
| Epoxy instead of wood possible? | Vhull | Fiberglass and Composite Boat Building | 1 | 07-12-2006 06:55 PM |
| Epoxy to use on wood? | JoseSanchez | Materials | 4 | 05-17-2006 12:13 AM |
| To soak or not to soak ? This is the question! | VKRUE | Wooden Boat Building and Restoration | 4 | 04-09-2006 01:27 AM |
| epoxy still soft | cammo | Fiberglass and Composite Boat Building | 11 | 02-03-2006 11:46 PM |
| soft wood | viking4 | Wooden Boat Building and Restoration | 6 | 06-15-2005 09:22 PM |
