Old 10-27-2001, 06:18 PM
schoolproject schoolproject is offline
Rep: 10 Posts: 2
Small scale cargo boat
The boat must be 24x34x14cm or less must weigh less than 500 grams and be able to hold 3000grams for 1 minute through wave testing
Try to keep the materials and designs simple and cheap.
thanks for the help
Old 11-02-2001, 01:23 AM
Sorry I didn't answer before - I still think in inches and ounces rather than cm and grams: using the Unit Converter at http://www.digitaldutch.com/unitconverter/ that's 9.4" W x 13.3" L x 5.5" H or 9 x 13 x 5 and needs to support around 6.6 pounds and weigh less than 1.1 pounds.
I guess a good question would be how vigorous the wave testing is and what the critera is for "seaworthiness" - is the object just to not sink? If it's only for one minute I would think a barge like design built from foam core or even painted mat board would do the job just fine - maybe a few light balsa supports. I think you could even do a two chambered bottom with a few bulkheads inbetween so it would be less prone to sink and still stay under the weight limit.
Old 11-02-2001, 12:04 PM
Unless you need the structure to support a concentrated weight, better to keep the weight down as low as possible for stability. A bit of curvature or V will help it break the impact of the waves as opposed to going with a flat bottom and straight bowed barge, and the V or curved structure will help add stiffness. Sounds like a fun project. Let us know how it turns out.
Old 11-03-2001, 04:22 PM
Rep: 10 Posts: 2
i was thinking of a cone bttom a v is for moving vessles this one doesn't need to move a cone would support all the waves right?
thanks for the help
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
TP52s mighetto Sailboats 2052 09-06-2007 10:46 AM
Materials for small boat??? Rich M Fiberglass and Composite Boat Building 16 08-16-2005 04:49 PM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 10:08 AM
Small Boat Drag Question....help! Biomechanist Boat Design 2 10-31-2004 08:36 AM
