Old 07-31-2006, 10:03 PM
jedkins jedkins is offline
Rep: 9 Posts: 26
Sleeving a mast
Hi , Can anyone tell me the best way to sleeve a mast.? Mast in question is a Hobie 16. The sleeve could either go about 4 feet from the mast base or about 4 feet from the masthead. Also where is the most stress on a mast,
near the bottom or the top? Thanks
Old 08-09-2006, 01:27 AM
Rep: 1397 Posts: 7,215
What do you mean by sleeving? Is it broken?
Old 08-21-2006, 03:36 PM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
How much for a new one?
You have previously posted the same question. It seems that you were unable to do or not happy with the two different solutions offered.
I doubt that you will receive a better solution to fix the old broken one than what you have already.
This leaves you with the only other option, replace the broken mast with a new one. Otherwise buy an old Hobie 16 with a good mast and build the boat up using the best parts of each cat.
Old 08-26-2006, 11:31 AM
SAE140
For such a small section mast - unless you're going for an external sleeve, I wouldn't bother. I'd be inclined to make a solid wooden plug that would fit snugly into the existing sections - about 18" long (9" inserted into each half). Coat the wood with epoxy *before* inserting it, to ensure that it's waterproof and will not swell in service. Invert the mast so that the repair is at the top.
From your previous post, you mention that you only need 2 feet or so from the break ? In that case, consider making up a wooden tip for the mast, along the same lines as above.
Colin
The all-in-one Mast katfish Sailboats 10 04-16-2010 08:45 PM
mast design-how do you go upon calculating the effect of the sail on the mast??? airturb Sailboats 34 02-21-2005 10:55 AM
Forces on the mast ArZillO Sailboats 0 10-28-2004 11:33 AM
mast dobsondwd Sailboats 6 08-29-2004 09:52 AM
Mast proportions Guest Sailboats 3 03-09-2004 08:39 AM
