Old 09-25-2009, 01:30 AM
mb2778 mb2778 is offline
Rep: 10 Posts: 10
Two things that I've picked up that also make epoxy cleanup a ton easier:
-next you're putting PVA on something, coat your tools and mixing buckets in the lightest coat. once the epoxy dries, it'll come right off everything.
-use lavasoap to clean off epoxy. it's absolutely amazing how easily this gets everything off.
An obvious one that I discovered early on is to wet out your lay up on waxpaper before applying it to the mold.
that multiple-gloves idea is brilliant!
Old 09-25-2009, 08:32 PM
Rep: 2891 Posts: 8,789
Simple tricks . . . get 'em drunk first . . .
Old 09-25-2009, 08:40 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1782 Posts: 2,979
This is a great thread. I hope anyone considering a build finds it before they have to learn things the hard way.
Old 09-26-2009, 12:19 AM
aka Terry Haines
Rep: 1682 Posts: 2,810
I've mentioned this before on the forum but this is the right thread for it so here it is again:
I cover a table with insulating foam then I can lay a sheet of ply on it and use a handheld circular saw. Way quicker and better than trying to run a jigsaw along the edge of a table, and safer than feeding the ply through a table saw too. I use a miniature panel saw, 3-1/2" (85 mm) blade, modified the pointer so it is the exact width of the blade so I can cut accurately on either side.
My saw has a zero clearance baseplate already, but a ply plate can be fitted to regular saw. Just fasten the ply then lower the blade through it to make the slot. Much cleaner cut.
Dances with Turkeys
Old 09-26-2009, 07:52 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Isn't that child labour....i thought that was stopped years ago.
Any tricks for stripping chrome? bntii Wooden Boat Building and Restoration 20 03-28-2008 07:30 AM
Infusion RTM ? Tips & Tricks ? Erwan Fiberglass and Composite Boat Building 2 07-09-2007 12:41 PM
simple question Leron Software 4 06-16-2007 09:56 AM
Tips and tricks for perfecting your vacuum-bagging methods duluthboats Fiberglass and Composite Boat Building 0 02-23-2007 03:25 PM
Cold Molding Details and Tricks Thumper Wooden Boat Building and Restoration 7 01-19-2007 02:13 AM
