Old 06-05-2009, 08:40 PM
BristolW BristolW is offline
Rep: 10 Posts: 7
Simple Stitch and Glue Car Top Carrier Advice
I came up with a simple design for an enclosed gearbox for my windsurfing equipment. I have never built anything stitch and glue before and don't know how strong it will turn out (specifically the butt joints) or what materials to use. See attached pdf!
Old 06-05-2009, 09:37 PM
Rep: 1397 Posts: 7,215
It's a rectangulat box. All you need it to put a 1X1 corner glued and screwed.
Old 06-05-2009, 10:15 PM
Rep: 10 Posts: 7
I like your idea better. Then maybe I would not need epoxy and could just use polyurethane on the inside and paint on the outside? What about the best choice for wood?
Old 06-07-2009, 05:59 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Also, for the curved bits on the sides, try half sections of pvc pipe, with a layer of Fibreglass Resin and Cloth over it. I would do a curved rear end also, as there is a lot of drag on sharp, squared off trailing surfaces.
You could fibrelgass the entire top section in the process, and overlap the curved PVC pipe sides, to make it really tough and longlasting.
A recent article in 'Professional Boatbuilding Magazine" suggests painting an initial layer of Resin over the sanded plywood, and when that starts getting tacky, lay FG cloth over it and wet it out.
If you used foam or other 'shaping' sections on the 'roof', to give a corrugated effect, you would get double the strength for the same weight.
stitch n glue Pelican? Phildave Boat Design 0 02-04-2009 07:32 AM
stitch and glue? kayakn Wooden Boat Building and Restoration 4 07-22-2008 12:08 AM
Plywood Stitch and glue? ahulting Boat Design 6 08-21-2007 09:08 AM
Stitch and glue restoration zoso Wooden Boat Building and Restoration 9 07-11-2006 06:23 AM
stitch and glue Boatbuilding 2 06-27-2002 09:33 PM
