Old 12-08-2002, 11:31 PM
dreamboat8 dreamboat8 is offline
ships wheel
Does anyone know where I could find plans or books on building a ships wheel. I'm building a 53 Bruce Roberts. Thanks Rich
Old 12-09-2002, 12:36 AM
Jeff's Avatar
Jeff Jeff is online now
Moderator
Rep: 921 Posts: 1,371
Welcome to our forums Rich,
Have you already talked with Glenn Ashmore or seen his site at:
http://www.rutuonline.com/html/steering.html
Old 12-09-2002, 12:45 AM
Jeff's Avatar
Moderator
This book may or may not be relevant:
25 Woodworking Projects (Woodenboat Series) by Peter, H. Spectre (Editor)
Projects for the novice and expert, Projects for the shop or on board. Projects for anyone wanting to fulfill their nautical desires. Here are the best woodworking projects shown in WoodenBoat magazine. They range from a simple bailer to a stunning ship's wheel. And in between are oars, doors, spars, skylights, and much much more.
200 pp., illus., softcover
Old 01-22-2003, 10:30 AM
capt-john capt-john is offline
Rep: 10 Posts: 4
custom wheel
Make, out of wood, the outer rim and the hub as a form to later take to your local foundry where they can use it to make a mold and in turn pour a bronze or aluma-bronze (mix of aluminum and bronze, a bit harder to work but won't tarnish after time). Then all you need are the spokes and handles... and to do some drilling and tapping too. The kewl thing is, if you make the rim deep and wide enough you can get those little plastic letters they sell for signs at stationary stores (you know, the letters can be moved around) and stick them to the rim before it gets to the foundry so everyone else knows who dun it...... put your name, the boat's name, the year of completion. You decide. John
Old 02-20-2004, 06:27 PM
Donald McKuin
Ship Wheel
I Have just started a design on a ship wheel. I am looking for some input. Do you have autocad4+. I can send you my ideas
Donnie
Old 02-25-2004, 10:23 AM
colinstone colinstone is offline
Rep: 10 Posts: 44
I've just built a 95cm diameter ships wheel. Rim was laminated from 1mm oak veneer in 2m long strips, 2 inches wide to a thickness of approx 38mm - 1 1/2 inches. 2 inch height then planed down to match laminated thickness. Outer corners were rounded off using a 19mm radius router cutter.
Hub turned from a piece of elm, 8 sockets bored for spoke inboard ends and brass bush sits in centre to take shaft to steering pump. 8 13 inch spokes turned from fench oak on a drill powered lathe. Difference in the 4 diameters of the spokes is less than 0.25mm - so it is very nearly a circle. Took around 80 hours to build.
Photos of Cruise Ships, Yachts, Tankers etc wanted! Yachting Marketplace 1 10-28-2004 05:48 PM
How do you rig wood-spoke wheel steering? Guest Wooden Boat Building and Restoration 1 03-19-2004 09:34 PM
Ships Curves Boat Design 1 10-01-2002 11:05 PM
Back to the drawing board...... Willallison Option One 14 05-29-2002 09:08 PM
Yachts that is ex navy ships Peter H Boat Design 3 04-06-2002 11:52 PM
