Old 05-23-2005, 11:47 PM
ducaes ducaes is offline
Rep: 10 Posts: 5
sealing up fuel tank fittings
hi guys, need your suggestion/view on this ..
i'm buliding frp tank with vinylester resin..problem is that how should i go about sealing off the fuel bronze fiittings for the fuel line i.e. adding sealant for leak prevention..
previously i use 3M 5200 but recently there been complain on the fuel line being clogged up by the disintegrate sealant..been told that 3M 5200 is not fuel/oil resistant..anyone out there can recommend any good sealant that can do the job?
thanks in advance ..
hudson
Old 05-24-2005, 03:04 AM
Arrowmarine Arrowmarine is offline
Member
Rep: 10 Posts: 107
We used to use a really good product, but damned if I can remember what it was. I'll make a phone call tomorrow and find out and I will get back to you.
Peace, Joey
Old 05-25-2005, 04:40 AM
Rep: 10 Posts: 5
thanks..
www.jamtank.com [ malaysian underground music scene forum ]
Old 05-28-2005, 01:34 PM
Rep: 1397 Posts: 7,216
If you are putting metal fittings to frp, epoxy may be a solution.
Old 06-01-2005, 03:37 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Contact 3M, Locktite, ITW Plexus or Sika. They all make good fuel grade sealers. I found a high quality oil resistant instant gasket material that would work great at my local hardware store. Locktite makes it, and it is orange.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
FRP Fuel Tank Fittings? Fixin2 Fiberglass and Composite Boat Building 1 03-04-2005 02:45 PM
Fuel tank inquiries. Hou-Chap Fiberglass and Composite Boat Building 5 03-04-2005 09:02 AM
Fuel tank placement? Capt. Chris Boat Design 19 02-11-2005 08:46 AM
Fuel Tank Setup Hiptrip Boatbuilding 7 06-10-2003 09:26 AM
