Old 06-12-2009, 10:41 AM
tdsherman325 tdsherman325 is offline
Rep: 10 Posts: 3
sealing the hull
I'm in the planning phase of building my first boat, a 12' rowboat. It's from very easy plans and I hope I don't have too much trouble.
However, the plans that I have are kinda old and, when sealing the chines to the transom and such, instruct the use of twine and white lead. Twine I can get, but I'm pretty sure that they don't sell white lead anymore. I'm even more sure that I don't want to use it.
So, what can I substitute for the white lead?
Thanks,
Terry
Old 06-12-2009, 11:23 AM
Rep: 10 Posts: 3
Here are the plans if anyone needs to see them.
Like I said, it's a very simple and easy design. I wanted to start with something fairly uncomplicated.
Thanks,
Terry
Old 06-12-2009, 01:13 PM
Rep: 1397 Posts: 7,215
Use polysulfide and you won't need the twine
Old 06-12-2009, 04:22 PM
Rep: 2891 Posts: 8,789
Gonzo's got it, use 3M 101 (polysulfide) and pack it into the seam tightly with a plastic applicator or putty knife. You can sand off excess when fully cured, but this can take a while depending on conditions. Hot and humid helps the cure. Hanging soaking wet towels over the area really helps.
Old 06-13-2009, 01:08 PM
Rep: 10 Posts: 3
Exactly what I was looking for; thanks!
Of course, at $30 a 10 oz tube, the sealant is likely to be the most expensive part of the project now, but, as I don't particularly want to have to dredge the boat out of lake Fort Phantom, I suppose the cost is worth it.
Thanks Again,
Terry
sealing wood computeruler Boatbuilding 18 08-19-2008 12:22 AM
Sealing your faired hull.... Roly Materials 3 11-04-2006 02:26 AM
Sealing a motor well? RHough Sailboats 3 12-03-2005 02:32 AM
Sealing with Silicone? Ok J Powerboats 16 06-11-2005 09:45 PM
sealing fiberglass alvingra Boat Design 2 08-25-2004 05:52 PM
