Old 12-27-2006, 01:07 PM
tom_fry24 tom_fry24 is offline
Rep: 10 Posts: 16
From scale model to full size.
A few months ago I started the process of building a boat, after consulting the threads regarding design I decided to build a model first as I have min computer design experience. My question now though is what is the best method for going about using the model to make the full sized thing? What is the best way of getting some kind of plan/cut outs out of the model?
Also I made the model out of wood... which was very enjoyable but I was wondering if I want to make another model what is the best material to use? Some thing moldable? and then also how do you get both sides of the mold to be identical? Thanks for your help in advance.
Old 12-27-2006, 02:15 PM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 461 Posts: 689
Hi Tom
Working with changes in scale is not as simple as it might seem. For example, if you were to increase length by 50% (i.5 times), beam, depth and freeboard would increase by about 1.33 times to maintain the original proportions. Similarly, sail areas, section areas hull volume etc. all change at different multiples.
Try and get hold of the work of H M Barkla of the University of Saint Andrews, Scotland who has done calculations in this area. This info is also in chapter 2 of the book Principles of Yacht Design by Lars Larrson and Rolf R Eliasson – pretty much a standard among small boat designers.
Of course the ultimate question is will the boat float. For example, what is the volume displacement, pounds per inch immersion and a myriad of other criteria which go towards a boat that not only floats but performs well? This is best done by “normal” design methods and calculations where everything is scaled to the actual finished size. Again, the book mentioned is an excellent source of information.
full scale plans for 65' sailboat $400,miami,fl. 7393452 Marketplace 0 12-10-2006 06:46 PM
full scale plans for 65' sailboat $400 7393452 Marketplace 2 11-08-2006 11:09 AM
Model to full size jammer Boat Design 6 11-05-2006 03:12 PM
Scale Model vs. Full-size AstroTux Boatbuilding 3 08-08-2006 07:14 PM
Scale model performance small cat Boat Design 6 11-22-2002 10:58 AM
