Old 12-22-2002, 08:46 PM
mbrault mbrault is offline
Rep: 10 Posts: 4
Sail Boat Plans
Looking for some boat plans with the following criterias:
Length: 42 feet
Rig: Ketch / schooner
Hull Potential max Speed: 12-15 kn
Building material: Steel / alu
Hull: Single or multiple chine, long keel
The boat will be used for long passage and cruise for 4 people. It would require to be oriented towards seeworthyness prior to speed performence. On baord motor of min 40 HP is required. Autonomy of 45 days would be a target as far as living aboard. I have alot of experience in woodworking / mechanics... but this will be our first experience in boatbuilding. I would prioritize simplicity and ease of integration over the inevitable "look" issue.
I am under the ipression that Steel would be a better choice for my project over alu. anyone had experience with both alu and steel boat? Pros and cons?
Would anyone have tips or suggestions please?
Martin
Old 12-22-2002, 11:06 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
Hi Martin,
Here are two sites that will give you something to think about.
http://www.kastenmarine.com/index.htm
http://www.stadtdesign.com/
Gary
Old 02-05-2003, 12:07 AM
Rep: 1397 Posts: 7,215
Try Bruce Roberts. He advertises in many magazines. I don't know if he's got a website. His plans come with full size patterns and have first time builders in mind. They look pretty good too.
Old 02-05-2003, 12:56 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
A link to the Bruce Roberts Web Site
Spray 40
Spray 40 Pilot
Spray 45
Old 02-08-2003, 09:39 AM
Polarity Polarity is offline
Rep: 148 Posts: 480
www.tedbrewer.com
www.dixdesign.com
Not sure you are going to get 12-15 knots out of a 42ft yacht though. Not unless its on a trailer or at 60 deg S.
You need a cat for that!
Old 03-21-2003, 12:26 PM
Paul Ex Paul Ex is offline
Speed of your project boat
Hello!
The 12 to 15 knots speed is only possible with a planing hull, build in very strict weight limits using carbon fibre etc.
In a 42 ft cruising boat, 6 to 7 knots average speed is more the range to look at.
But don't mind: sailing is great fun, at any speed, just stay dry and warm and well fed!
Paul
Old 03-29-2003, 08:56 AM
Martin: I would commend to you www.metalboatsociety.com concerning the aluminum/steel debate, as well as information on various designs that may suit your needs. I would suggest caution with respect to stock Roberts designs: numerous of his designs have suffered total failure of the skeg and consequent sinkings. Roberts suggests that his skegs are designed to be 'sacrificial' - a suicidal concept that masks a serious design flaw. Info. concerning the same can be found at the above mentioned site.
Brad
Old 04-13-2003, 10:01 PM
Denis Ganley has some nice ketch designs for steel. I'v seen his plans at fairmetalboats.com
John M
High-Speed Waveless Boat waveless Boat Design 82 10-10-2005 08:01 AM
Lasers mackid068 Sailboats 24 08-09-2005 11:10 PM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 11:08 AM
help in purchasing 1st sail boat bc22 Sailboats 0 08-05-2004 03:31 AM
Small sail boat, free plans. duluthboats Open Discussion: All Things Boats & Boating 5 10-17-2003 06:21 PM
