Old 08-21-2008, 06:38 AM
ten thou .010 ten thou .010 is offline
Rep: 0 Posts: 3
rudder nasa foil sect
lost my book, can anyone point me to nasa foil sections, thanks
chord 500mm
span 750mm
stock 63.5mm at balance axis
nice place this
Old 08-21-2008, 07:02 AM
Previous Member
Rep: 0 Posts: 0
Look here:
http://www.ae.uiuc.edu/m-selig/ads/c...atabase.html#N
Scroll down to NACA and choose your poison. You can get a coordinate file or gif image of the nominated sections.
It seems you are indicating it is 63.5+mm thick and 500mm chord. That is just over 12% so I suppose you are looking for a NACA0015.
Rick W.
Old 08-21-2008, 07:54 AM
Rep: 0 Posts: 3
danki
but the GIF FILE, brings up an air wing section?
Old 08-21-2008, 05:17 PM
Previous Member
Rep: 0 Posts: 0
http://www.boat-links.com/foilfaq.html
(1) The values listed beneath the NACA numbers are the distances + and - to the foil surface from the centerline in % of chord.
(2) Cut values for 0012 and 0018 in half to get 0006 and 0009. Double 0015 to get 0030. Halve 0006 to get 0003.
(3) It's conventional to make the chord 5% longer than you really want, and then slice off the last 5% to a blunt edge after laying out the foil profile. Example: you want a 20-inch chord rudder. Calculate profile based on 21 inches, leaving off last 5% or 1-inch when laying out.
(4) The nose of a NACA 00-- foil is always circular. Fair this in by eye as best you can using a compass or template or some sort (bottom of McDonald's coffee cup). This radius can be generated by the formula referred to above. (I'm still not talking.)
(5) The thickness of a NACA foil is always greatest at 30% of the chord from the nose.
Distance
From Nose NACA
0012 NACA
0015 NACA
0018 NACA
0021 NACA
0025 NACA
0030
1.25 1.89 2.37 2.84 3.31 3.95 see note 2
2.50 2.62 3.27 3.92 4.58 5.45 ----
5.00 3.56 4.44 5.33 6.22 7.41 ----
7.50 4.20 5.25 6.30 7.35 8.75 ----
10.00 4.68 5.85 7.02 8.20 9.76 ----
15.00 5.34 6.68 8.02 9.35 11.14 ----
20.00 5.74 7.17 8.61 10.04 11.95 ----
30.00 6.00 7.50 9.00 10.50 12.50 see note 5
40.00 5.80 7.25 8.70 10.16 12.09 ----
50.00 5.29 6.62 7.94 9.26 11.03 ----
60.00 4.56 5.70 6.84 7.99 9.51 ----
70.00 3.66 4.58 5.50 6.41 7.63 ----
80.00 2.62 3.28 3.94 4.59 5.46 ----
90.00 1.45 1.81 2.17 2.53 3.02 ----
95.00 0.81 1.01 1.21 1.41 1.68 ----
100.00 0.13 0.16 0.19 0.22 0.26 ----
All Measurements in Percent of Chord
rudder foil selection Hravn Boat Design 18 02-17-2011 11:30 PM
NASA GAW Foil Section Dey Boat Design 3 01-25-2010 04:51 PM
Best rudder foil shape Landlubber Boat Design 6 09-10-2007 12:34 PM
Rudder Centre of pressure with PMB Foil ?? MikeJohns Boat Design 15 08-09-2007 11:44 AM
Aero foil rudder speed limitation Ian W Boat Design 3 10-04-2004 06:11 AM
