Old 02-16-2011, 05:56 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
Is this right? (foam)
Today, I worked 7 hours. Here's what I got done:
1) Applied packaging tape to 1/3 of a 45' mold.
2) Put down 2 (!!) pieces of 1" (25mm) A600 foam... possibly not well!
Shouldn't I be getting more done than that? I only took a break for 20 mins to get some fast food and ate it at the boat shed fast. My first fast food in many years. The transmission went in my RV that is at the boat shed, so I had some odd living situations going on and fast food was the only thing.
Back on topic, putting packaging tape on 1/3 of the mold and getting 2 foam pieces down seems a bit lacking. The foam was much more difficult to work with than I had anticipated.
Here are some pictures of what I got done. To me, this looks very bad, considering how much effort I made making a perfect mold. The foam is not sitting down all the way on the mold battens and I toasted both sheets.
Sharpest curve of the bilge... the transom area of the hull. This took hours to get in place, but it does look good. There are a few very small warps, like the next picture.
Here is a bad warp in the next panel up from the stern. It just doesn't want to sit down. I broke some 3mm plywood washers trying to force it and the screw went right though the foam.
Here is what they look like in place. Toasted like a mutant toxic marshmallow... both of them. Do I worry?
What do I do about the toasted part? Sand it off and put bog there to even it out?
How do I get my foam more fair?!?
I see the Ian Farrier sites and they all seem to have no problem. Neither does the guy from fram.nl. Granted they all use 3/4" and I'm using 1", but it seems everyone is doing a better job...
Do I just not worry about all the waves and burnt foam? Do I just bog it all out later? I can't keep blowing through foam sheets practicing. I need to use them in the real boat.
On the positive side, I no longer feel the effects of hydrogen cyanide gas when burning core cell. I am wearing a hazmat spacesuit with forced air into the full hooded head enclosure. It pulls air along a hose from outside the building, which is fantastic. It even came with a HEPA filter inline!
Any advice for me on the foam?
Also, how do you use the screws with plywood washers and the screws that go in from the back of the mold? Do I not touch the screws in the back of the mold until after I shape the panel with the plywood washer screws that go in from the front? I tried pulling the foam down with the screws in the back and they just strip the foam. How do people usually work these two types of screws together?
Is this right?  (foam)-imag0215.jpg  Is this right?  (foam)-imag0217.jpg  Is this right?  (foam)-imag0214.jpg
"You can't solve all of life's problems with epoxy" - My Wife
Old 02-16-2011, 06:46 PM
rberrey rberrey is offline
Rep: 69 Posts: 287
Cat for my own sake i hope you can do more than 2 sheets in 7 hours. What if you epoxyed some small tabs where your warps are on the batter board side, maybe the screws would pull the foam up a little tighter. I,m sure someone will post some solutions. rick
Old 02-16-2011, 07:01 PM
The battens (batter boards?) are already pre-drilled with screw holes in them. The screws were stripping the foam when I tried pulling them down from behind. That's why you see all the screws on the front side. The front side screws were to assist the foam in lying properly.
I'm not sure if I'm supposed to use the front screws with plywood washers to get the foam to the right shape and *then* screw the back ones in, or what...
Wrestling with this foam is a lot harder than I had thought. I may have to go back to getting the hot box running, but I'm waiting on some input.
Old 02-16-2011, 07:32 PM
Rep: 1493 Posts: 7,447
You can use drywall screws with the head sunk in the foam. You simply rip them off when you take the battens out later.
Old 02-17-2011, 12:24 PM
The kerf cuts worked really well as an option.
In my female batten mold, do I lay them with the kerfs in toward the interior of the boat, or with the kerfs facing outward toward the exterior of the boat?
They laid up very nicely with the kerfs facing in... but there will be tiny little air gaps inside the core if I do that because the kerfs close up completely and can't be bogged inside.
Old 02-17-2011, 12:27 PM
The kerfs are always on the outside of the curve unless you lay the foam wet with resin.
Old 02-17-2011, 01:34 PM
I'm getting conflicting info on this. Some other builders said it was fine for the kerfs to go inside. Hmmm... a few more votes?
Old 02-17-2011, 01:42 PM
Check with the designer, that is the only vote that counts.
Old 02-17-2011, 03:13 PM
That's a good point.
Look at how great it came out with the kerfs though.
I was able to put this up in a total of 15 mins today, including cutting the foam piece from a scrap foam panel, cutting the 1/2" deep kerfs and screwing it all into place. Since it is the absolute transom, it required a tiny bit (30 seconds?) of heat just to be sure the remaining 1/2" of Core Cell below the kerfs didn't break.
What a process though! Hope I can use it. I suppose I can since the kerfs are a little wider on this one thanks to the larger saw blade I used. I can fill them in with bog, no problem.
Is this right?  (foam)-imag0218.jpg  Is this right?  (foam)-imag0219.jpg  Is this right?  (foam)-imag0220.jpg
Old 02-17-2011, 06:29 PM
Rep: 69 Posts: 287
Cat , looks good, are you using a heat gun? rick
Old 02-17-2011, 08:01 PM
No, I am using one of these:
The heat gun puts out too narrow of a path of heat and scorches the foam. Also, one part will cool before you heat the next part with the heat gun.
It literally took between 30 seconds and a minute to heat the un-kerfed side of the foam enough to do the bend in the picture. Sure beats the 15 mins+ it took to burn the foam last time.
Old 02-17-2011, 08:54 PM
Those kerfs are huge. Is that the usual method for those boats? It will take a lot of resin and increase the weight. The kerfs on most boats are knife cut.
Old 02-17-2011, 09:46 PM
No, not the usual method at all. Normally, it's bead and cove strip planking or thermoforming the foam.
I was experimenting to try to find something that would work with this 1", A600 (25mm, 116kg) foam. It is very difficult to bend.
Old 02-18-2011, 05:11 AM
fg1inc
As Gonzo said, those kerfs are huge. Not only will they add weight, but the rigidity of the resin or bog will cause multiple stress risers in you panels. In other words, as the panel flexes, the rigid strips cannot flex and will start to push the laminate off the foam.
Old 02-18-2011, 05:13 AM
It will look like the seams on a planked wooden boat.
Where to get foam? Chris Ramsey Boatbuilding 6 05-24-2010 04:23 PM
About that foam? 360weatherbound Boat Design 12 03-29-2010 06:05 PM
foam brokensheer Fiberglass and Composite Boat Building 17 08-19-2009 01:17 PM
How much foam huntermike32 Wooden Boat Building and Restoration 1 10-18-2005 07:59 AM
Name That Foam!!! kudu Materials 9 01-19-2004 10:44 AM
