Old 04-09-2005, 07:25 AM
jetboatjill jetboatjill is offline
Registered
Rep: 10 Posts: 28
Restored boat won't lift/float
We recently fulled restored a 1971 Sidewinder jet boat. We gutted the boat and basically started from scratch. We used the original 455 Olds engine block and rebuilt it using all new parts. We used the original motor mounts, etc. When we went to launch the boat for the first time after restoration, the transom would not lift / float off the trailer. The boat took on water due to the exhaust being below the water line. Does anyone know what to do or how to fix the problem to get the back end of the boat to lift / float? The boat is made of fiberglass, not wood. We have researched, asked other people and no one seems to know why the transom won't float. We have not added any extra weight, not that significant amount of weight to make the boat not to lift & float. Can someone PLEASE HELP us????
Old 04-09-2005, 08:41 AM
DaveB DaveB is offline
Rep: 11 Posts: 128
I guess you could try plugging the exhaust until you get the boat in the water... sounds like the angle of the ramp is a bit too steep...
Might wanna do a soap test to be sure that there are no other leaks though as it'd be no fun to sink deeper. Might be prudent to leave the trailer under it for a while (15 min) even once floating and use a big truck (preferably 4x4) that won't have any problem hauling the whole mess out with the boat full of water... A shallower ramp might be a good idea too...
Good luck with it...
Cheers,
Dave
Old 04-09-2005, 11:29 AM
Registered
Rep: 10 Posts: 28
THANKS so much!
THANKS so much for your reply. We do not have a 4X4 truck, we have a Dodge Dakota. We'll have to try a ramp that is not so steep. THANKS for your suggestion! jetboatjill
Old 05-09-2005, 04:23 PM
polar polar is offline
Seen this happen before, they forgot to take the strap and binder off the boat before they launched......Hum
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
High-Speed Waveless Boat waveless Boat Design 82 10-10-2005 08:01 AM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 11:08 AM
Concept Boat Design Contest Tad Boat Design 16 09-17-2004 11:13 AM
