Old 02-17-2007, 12:36 PM
Coreyb760 Coreyb760 is offline
Rep: 10 Posts: 7
Restoration Questions (Can I bondo my fiberglass boat?)
I have a couple questions, is it possible for me to bondo over the fiberglass on the boat? If not can i fiberglass over the paint or do i have to take it down to the old fiberglass?
Old 02-17-2007, 01:26 PM
Rep: 505 Posts: 1,658
first please be more precise of your intentions,,,if you are repairing damage ,,or refinishing the hull.however for patching use a fiberglass product ,,such as dura glass with fibers in it,,bondo dont last ,it dont flex well and it aborbs moister and yes take it down to the core material,,,,,picture of your project would be cool .good luck ,,longliner
Old 02-17-2007, 11:51 PM
Rep: 10 Posts: 7
I am refinishing the hull. Here are some pictures of the boat it is a 66 flatbottom "fresno". Im just trying to fill in the valleys in the fiberglass so when i paint it it looks good.
Old 02-18-2007, 12:43 AM
nice boat ,,use dura glass ,get it at car part stores or car paint stores,,,,what are you gonna paint it with? longliner
Old 02-18-2007, 10:54 AM
Rep: 10 Posts: 7
not sure, i was just gonna leave it up to the paint guy..... any suggestions
Old 02-18-2007, 10:56 AM
Rep: 10 Posts: 7
When I fiberglass it should I take it down to the old fiberglass? And does it matter what kind of sand papper I use?
Old 02-18-2007, 10:58 AM
Rep: 10 Posts: 7
And I already bought fiberglass jelly do you think that would work?
Old 02-20-2007, 07:00 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
Use a waterproof fiberglass filler. Grind any and all repairs down to original glass with 24 grit. Sand filler with 80 grit than 180 than prime with a hard epoxy primer. Let your painter finish to whatever he wants to use. I like 2 stage urethanes. Have fun!
Old 02-26-2007, 10:32 PM
Rep: 10 Posts: 7
Does Anyone have a second opinion on what kind of paint to use?
Old 02-27-2007, 04:46 AM
Rep: 2891 Posts: 8,798
Paints are user preference, after you get past the hardness factor. The hard stuff is the two part polyurethanes, but it also is more difficult to apply. Any other paint choice will be less durable, less hard and will have to be justified in some way, which is an end user issue. Most painters know their products and are comfortable with them, so it's a wise choice to let a painter select the paint type for your application. Modern paints aren't like the good old days, when some spirits and paint got tossed in a cup and you shot the job. Now you need to understand the product, or you'll have one screwed up paint job, unless it's house paint coming out of a Wagner hand shaker.
painting a fiberglass boat questions revshot Fiberglass and Composite Boat Building 3 02-12-2006 04:43 PM
Wooden Ski Boat Restoration Questions dhulv Wooden Boat Building and Restoration 4 06-28-2005 09:59 PM
New Restoration Project Questions IHTFP Fiberglass and Composite Boat Building 4 05-18-2005 01:49 AM
new construction questions I just have to ask about fiberglass layers. donjames Fiberglass and Composite Boat Building 4 08-19-2004 05:32 PM
CPES, Epoxy and Fiberglass Questions Guest Boatbuilding 4 09-04-2003 09:06 AM
