Old 02-09-2005, 05:13 PM
AnthonyYacht AnthonyYacht is offline
Mechanical Engineer, MSME
Rep: 10 Posts: 19
Request for Proposal: Tug Yacht 24
I am looking for boatbuilder/designer to build 24 ft aluminum (or Corten) tug yacht. All technical data in scantlings section is for aluminum construction.
I provide concept tug design. I want it look like that. Exhaust will serve as head/shower compartment in the future.
I understand that professional improvements might change design, but I want keep it close to mine as much as possible.
Read attached Request for Quote and CAD renderings for details. CAD drawings are also available to serious builder/designer upon contract agreement.
Please, provide quote in private confidence to the following address: AnthonyYacht@yahoo.com
Request for Proposal: Tug Yacht 24-tug-24-aluminum.jpg  Request for Proposal: Tug Yacht 24-tug-24-aluminum-side.jpg  Request for Proposal: Tug Yacht 24-tug-24-aluminum-top.jpg
Request for Proposal: Tug Yacht 24-tug-24-aluminum-front.jpg  Request for Proposal: Tug Yacht 24-tug-24-aluminum-back.jpg
Old 03-02-2005, 09:34 PM
tmarks11 tmarks11 is offline
Rep: 10 Posts: 2
Flat bottom and near vertical, single chine sides? You might want to rethink that, as she will give a very uncomfortable ride in anything but the most sheltered of waters. Also, why 12' beam on such a short boat? She is small enough to be trailerable, but not at that width.
You might want to look for existing designs, of which their are several already in existance for aluminum construction. A designer will probably charge you $6k just to draw up plans for your boat, but stock plans would run run $300-700.
I can think of a few right away. The Boojum 25 by Michael Kasten immediately pops to mind.
Boojum 25
The Fred Murphy 26 by Al Sorenson.
Fred Murphy
I am sure some other denizens can chime in with some other favorite designers?
Old 03-14-2005, 10:27 PM
asathor's Avatar
asathor asathor is offline
Rep: 10 Posts: 154
Are you for real?
I do not mean to offend you, but that project of far from the RFP stage.
You can't insists on a hull design that is not suited for sailing and ask other people to spend time on it without paying them.
A lot of the people coming here are professionals that need to make a living so I took it upon myself to say this out loud.
You should be able to hire a good navel architect for $100-$250 per hour to help you with the real design work.
May the wind blow briskly in your sails!
Old 03-15-2005, 08:24 AM
Rep: 10 Posts: 19
It does
It is not award winning design, but it floatable
And that more than enough
I am not building a "yacht" , but just self propelling barge.
Old 03-15-2005, 03:25 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
I saw you other posts. Go with marine plywood stitch and glue. You can do all the work quickly, without handling heavy sheets of metal, it's strong, and you don't have to be a welder/fabricator/boatbuilder. You can get all the plywood CNC router cut and drilled, all the materials are obscenely inexpensive. What about your "smokestack"? Plywood can be tortured into any shape by steaming or cutting grooves (I forgot the correct word here) on the inside of the curve. You want to go with metal because you're familiar with it, I think. I'm not going to comment on what I think it looks like.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 03-15-2005, 03:35 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
Asathor, you hit the nail on the head................
High Professional building & managing group of super yacht george_moy Services & Employment 1 04-23-2006 04:17 PM
Yacht Designer Seeking Contract Work jamiehides Services & Employment 0 08-30-2005 07:41 AM
Yacht Designer seeking employment jamiehides Services & Employment 0 12-09-2004 08:39 AM
