You don't always have teak on the deck, but screws and washers would still work. The non-skid probably needs to be renewed anyway. A 6" x 6" screw pattern would be about right for 1/2" plywood, 8" x 8" for 3/4". Prop it first and use pieces narrow enough to work with slightly compound curvatures. Much easier and neater. Easier to hold the shape by propping too, and you'd reduce potential lumpiness in flat areas. |
| Plywood can be tortured easily if it's thin enough by propping the middle. Unlike cold-molding, which requires pinning down the edges, doing it inside the boat only requires a stick of the right length every so often along the length of a wide plywood "plank". |
| I want my turnbuckles inside the boat! | Omeron | Sailboats | 3 | 06-28-2007 08:10 AM |
| acrylic for inside cabin | mattoc | Materials | 3 | 06-05-2006 08:26 AM |
| Balsa core vs. foam core | James Maldonado | Fiberglass and Composite Boat Building | 23 | 01-21-2006 11:12 PM |
| new way to light up the inside of your boat | Packeteer | Boat Design | 14 | 08-13-2005 12:03 PM |
| epoxy and glass inside and outside? and more | Nordson1960 | Wooden Boat Building and Restoration | 6 | 05-22-2005 09:26 PM |
