Old 02-09-2010, 03:30 PM
ikaminnear ikaminnear is offline
Repair grommet screw holes in aluminum arch
New to the forum and back into boating after a 6 year lull.
I bought a boat that has had 3 owners and it looks like each one of them had a "new" idea for canvasses. Hence, I have grommet snaps in fiberglass, aluminum arch and windshield frames.
I really want to do it right and could use assistance in covering holes and repainting aluminum....as well as refiberglassing and matching gelcoat.
Where do I start?
THanks
Ikaminnear in NJ
Old 02-10-2010, 10:06 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
Hi,
Welcome to the forum
I think the best way to repair the screw holes would be to weld them and then spot face the welds flush. With the arch removed take and have it media blasted then Stronium primer / epoxy primer / polyurethane paint...............but if it can't be removed and that seems like it is more money and work than it's worth. And If you fell like it is strictly cosmetics and the holes are small in diameter then I would look into several repair products.
On the more expensive side Devcon makes an Aluminum repair putty that has aluminum as part of the filler material or probably better and cheaper a good epoxy repair putty used for repairs in fiberglass. I would take a christmas tree shaped de-burring tool or a counter sinking tool to each hole to remove loose paint and corrosion around each holes outer opening (Just bevel the mouth and sand or grind away any loose paint and crusty aluminum) to where you get shiny metal. Then wipe clean with Acetone and spot prime with Awlgrip 545 epoxy primer then fill the holes, sand and reprime. (please note there is a wealth of info on this site regarding aluminum prep, the procedure I suggested is on the lower end of labor and materials, their are more involved and better ways) BUT this will work......finally sand the whole arch and primer again, then paint with quality marine 2 part PU poly U paint.
This is getting kind long, but you mentioned gelcoat, the arch is very, very likley not covered in gelcoat but rather paint.
If you have Questions regarding the polishing of the boats gelcoat, shoot some question and some pictures
Old 02-10-2010, 02:12 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
You can use a product like JB Weld, a gray metal-filled epoxy. Available in auto parts stores. Put couter sink bit to holes to expose more surface area and then fill and later sand flush. The stuff should last the life of the boat, I'd think. Under $10.00.
Old 02-11-2010, 08:32 AM
Rep: 67 Posts: 243
You know I don't know why the JB Weld didn't occur to me when I replied
Like Alan said that would be your best bet
Fill screw holes in transom? stimulous check Boatbuilding 11 07-15-2009 04:41 PM
Aluminum arch builder in Florida DeeDee Metal Boat Building 1 10-23-2007 10:32 AM
Filling old screw holes in deck... mdevour Fiberglass and Composite Boat Building 12 10-16-2007 07:09 PM
Aluminum arch builder in Florida DeeDee Sailboats 0 03-24-2007 02:09 PM
Screw holes Question mikefrome Wooden Boat Building and Restoration 2 11-12-2006 02:13 PM
