Old 01-01-2006, 04:44 PM
brewersgold@com brewersgold@com is offline
removal of molded cockpit sole from a viking 40
i am beginning the process of renovating a 1974 viking 40. i have soft spots under the molded cockpit sole. i need to replace the plywood floor that is under the fiberglass sole.
is it possible to remove the entire cocpit insert to access the floor and framing and fuel tank under without cutting it (the cockpit) up?
it looks as though it was installed before the deck.
have any of you guys ever run into this before?
Old 01-13-2006, 06:04 PM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
Im in the midst of it myself. the sole is best removed in a normal fashion and a lot of sweat.
Can anyone spare any gas today for a hamburger on Friday ???
Old 01-18-2006, 04:09 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Mr. Nekkid,
You need to double up your clamps on the exhaust system. Nice, clear picture! Sam
Old 01-18-2006, 07:11 PM
Rep: 37 Posts: 345
YOU Are right! and the extension pipe is rotted so Im putting in one new muffler, two new pipes and 20 new clamps
Old 01-18-2006, 07:46 PM
Rep: 37 Posts: 345
heres an update
a lttle spring cleaning, now heres a hitch. In order to install any longitudinals and bulkheads the boat must be blocked absolutely correctly. So its off to the shop tomorrow for a coupla jack stands to adjust the chine height before we tab the bulkheads in. Otherwise the glass sliding door wont open or close properly
removal of molded cockpit sole from a viking 40-bilgecoat1.jpg  removal of molded cockpit sole from a viking 40-cockpit-002.jpg
Old 03-31-2006, 07:28 PM
Rep: 37 Posts: 345
we,re getting there
just installed the sole supports to dry fit today
Old 03-31-2006, 07:30 PM
Rep: 37 Posts: 345
the other side,
Funny both sides rotted near the gas fills, maybe we will stop putting gas in
Old 07-10-2006, 03:02 PM
Harold Harold is offline
Rep: 10 Posts: 5
doesn't look like a 40 but the project looks good anways...
How is it going ????
Old 07-10-2006, 06:19 PM
Rep: 37 Posts: 345
Great
we have finished the boat and have had a lot of good comments. We had a television crew on board last week for a filming an episode of THE FIFTH ESTATE here in Canada and next week we are a turn boat in teh OSSTORONTO races. Damn thing better not sink. wife loves her new galley too
Old 07-10-2006, 09:20 PM
Rep: 95 Posts: 462
now put the galley to test bacon and eggs over easy for saturday morning
Old 07-10-2006, 10:09 PM
Rep: 10 Posts: 5
Vary nice, indeed.
We have a '73 Viking sportfish that needs the same work . I have already done the flybridge floor (from underneat) and to say the least it was very difficult to do. Can you imagine fiberglass resin dropping on you? I did it with balsa core,resin and cabosil. Have pics of it too. Will begin work on cockpit after this summer.
Harold
Old 07-11-2006, 06:27 AM
Rep: 37 Posts: 345
overhead?
you mean like this. I can volunteer to help if its in the winter
Old 07-11-2006, 08:33 PM
Rep: 10 Posts: 5
LOL Exactly!!!
Mine is a 40 sportfish. Was your cockpit sole balsa cored or plywood? Mine looks like balsa but will know for sure when work begins.
Harold
Old 07-12-2006, 04:53 PM
Rep: 37 Posts: 345
Bals
Balsa schmalsa , wet gooey old mush. We removed a lot of it and used foam
Old 07-12-2006, 09:53 PM
Rep: 10 Posts: 5
Thanks.
I will start a thread on the Viking 40 for coments from other owners if they are around here.
Hope to read from ya there.
Harold
Cockpit Floor Measurements rdeputy Boat Design 5 11-02-2005 08:45 AM
