Old 12-09-2001, 06:17 AM
Regulations for designing and building your own boat?
If you want to design and build your own boat, what regulations do you have to comply with? Is this different from state to state, or do some countries have stricter regulations than others?
Also, who can call themselves a yacht designer? How about a naval architect or a marine engineer?
Old 12-11-2001, 06:20 AM
Scott Scott is offline
Registered
Rep: 10 Posts: 41
In the United States the regulations for building a small boat are mainly just general safety regulations of the US Coast Guard (governing such things as maximum horsepower for very small boats, loading, flotation, builder and hull identification numbers, and emergency equipment.)
See http://www.uscgboating.org/ and specifically http://www.uscgboating.org/reg/reg_default.asp
The Federal statutes that authorize the U. S. Coast Guard to regulate the manufacture of recreational boats appear in Title 46, United States Code and the safety standards and regulations applicable to manufacturers of recreational boats and associated equipment are found in Title 33 of the Code of Federal Regulations and Title 46 of the Code of Federal Regulations.
These regulations govern the design and construction of recreational boats and include manufacturer certification, identification of boats, display of capacity information, safe loading, safe powering, flotation, electrical systems, fuel systems, ventilation, start-in-gear protection, navigation lights, and backfire flame control.
I haven't really considered much other than one-off construction -- I wonder what certifications would be required for boats over a certain length or boats built in a certain quantity, for example 6 or 12 of a design?
Old 12-12-2001, 05:27 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Not to drive the thread off topic, but I believe this post is worth mentioning:
http://boatdesign.net/forums/showthread.php?threadid=27
Old 12-20-2001, 12:19 PM
Jeff's Avatar
Moderator
Here is a fairly general USCG PDF file which details the fundamental safety requirements for home boatbuilders:
Safety Standards for Backyard Boat Builders
Old 12-21-2001, 08:42 AM
Steve Hollister Steve Hollister is offline
Registered
Rep: 78 Posts: 56
See also the site called
The New Boatbuilders Home Page
For a lot of information, including regulations
http://hometown.aol.com/spinners/index.html
Old 12-29-2001, 06:41 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
USCG? pah ! Check out the RCD
Lucky you lot in the USA, get a load of the RCD that we in Europe have to put up with:
http://www.ceproof.com/filescep/rcdover.html
Note the definition of "Home built boats"
Yep thanks to our wonderful Eurocrats - if you build a one off boat over 2.5m in your back yard you can't sell it for 5 years!
Also, if you commission a yard to build it for you, or even some of it, or have a kit professionally completed and it's 12m+ that's approx 6-10,000 $ for "certification" or its illegal to use it or sell it.
That includes bringing a boat in from the USA built after the cut off date.
The really crazy thing is, if it's 24m+ and you don't plan to charter it... you can do what you like!! (the MCA regulate pleasure yachts 24m-500 GRT - but only if it's for charter - there is a calculator for those regs at
http://www.nonstopyacht.com (choose "MCA Calculator" under services on left)
So home builders in Europe - make very certain you can prove you built it at home!
Paul
Old 03-14-2002, 01:38 PM
curtis73 curtis73 is offline
Rep: 14 Posts: 58
This thread is very interesting to me and I've followed the links. It appears as though it applies mostly to larger boats. It describes certain things like - uninspected boats travelling more than 3 miles offshore needing certain equipment. If I'm building a 17-foot pleasure boat, what needs to be done? I've seen coast guard courtesy inspection stickers, but is that necessary? How do I get a capacities plaque? I know that they are required in Ontiario where I do alot of boating.
Curtis
Curtis Mittong
Old 01-04-2003, 01:11 PM
Barry Barry is offline
Rep: 10 Posts: 3
I have spent a lot of hours as I am planning to build a 34 foot within the next year.. I have just ordered some information from
abyc American Boat and Yacht Council that has compliance regulations . Try them on their website.
Old 10-14-2004, 09:19 PM
JPAYNE JPAYNE is offline
Rep: 10 Posts: 2
Question/Hull Numbers
Who do I call about gettig hull numbers the coast guard in my area is giving me the run around.
Old 10-14-2004, 10:53 PM
carolina skiff carolina skiff is offline
scotty
Rep: 10 Posts: 4
Hey - hope you made it thru Ivan down there on Mobile Bay. In NC, our Dept of Natural Resources (same place you'd get a hunting or fishing license) will issue hull numbers for homemade boats. and, tell them to get the flora~bama built back soon!
Old 10-15-2004, 01:51 PM
Rep: 2891 Posts: 8,792
Typically the state issues a "Z" number for home built boats, unless you want federal registration, then the USCG's web site will get you there.
Old 10-15-2004, 04:45 PM
lprimina lprimina is offline
Rep: 35 Posts: 103
Here is the coast guards home page. They will be more than happy to help you out.
Most of the local Coastys dont know aboat the program.
Good luck
Ben
