Old 02-05-2010, 12:31 PM
BOOBOO7353 BOOBOO7353 is offline
Rep: 10 Posts: 2
Redoing floor what material??
Hey guys! I am currently stripping my floor out of my aluminum hull bass boat. It currently has 1/2" wood flooring with carpet that is some what spongey but i am just ready to replace it. Heres my question. I want something that will be strong enough to support me and not break after a little wear but i want something very light weight. My boat is not very fast it only has a 25hp motor on it but thats because of the lake i fish mainly. So i want to try and make it a little quicker by deleting some weight
Thanks in advance
Ben
Old 02-05-2010, 03:57 PM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
Whatever you replace it with will probably not save much weight. You might try slats of something instead of solid ply. You are getting rid of weight just by getting rid of the spongy, watersoaked wood. Leave the carpet off the new floor, it invites rot. A little sand in the paint (latex porch and floor enamel) will make non-skid. The new kind of treated plywood will corrode aluminum, don't use it. If you do, isolate it from the hull with rubber or something.
Old 02-05-2010, 04:57 PM
DianneB DianneB is offline
Rep: 74 Posts: 83
Very timely! I will be getting my new/old Sylvan home soon and the sole is in bad shape.
I was thinking of replacing the plywood and installing scuppers - I like scuppers - better to have a wave drain out the back than end up in the bilge - but I REALLY like duckboards and being able to see beneath the floor. No point in doing scuppers with duckboard decking LOL!
Still undecided .....
Old 02-05-2010, 05:27 PM
Rep: 10 Posts: 2
I am wanting to get away from wood like mayber aluminum or expanded metal or some kind of fiberglass material
Floor material besides wood gabedance Materials 9 07-06-2007 08:53 AM
Redoing my floor Steve71 Fiberglass and Composite Boat Building 2 04-30-2006 09:44 PM
Redoing the bottom of a boat help simba71 Boatbuilding 5 04-29-2006 10:32 AM
floor material crum731 Fiberglass and Composite Boat Building 4 08-19-2004 03:06 PM
redoing floor in bow rider ventnorbuilder Boatbuilding 4 07-23-2002 08:38 AM
